Author Topic: PROBLEM WITH SCAN FOLDER TV SERIES MED800X3D V4.02  (Read 22723 times)
Offline chrisdeburg
« on: December 03, 2017, 10:32:30 AM »
Hello,
for 2 months and for no reason, when I scan the serie tv folder to retrieve the multimedia information (fanart, folder, xml etc ...), the scan correctly imports the XML data, but no longer correctly files fanart and folder . They are present but are black without image at 0 or 2 Kb. So I have on the screen a black image and sometimes a red, black and white triangle.
If I use the function manually edit the system this blocks.
In the Movies folder, no problem, it works normally.
I reformat the disk but it's the same problem
Offline chrisdeburg
Re: PROBLEM WITH SCAN FOLDER TV SERIES MED800X3D V4.02
« Reply #2 on: December 03, 2017, 04:24:39 PM »
Tanks for your info. Is there a way to find a solution and scrap the images like the  movie folder ?
Envoyé de mon iPhone en utilisant Tapatalk
Offline mike_carton
  • Helpful Contribution Status: +13/-1
« Reply #3 on: December 04, 2017, 07:58:32 PM »
You now have to scrape on the PC. TVRename utility works well. There is a thread about it on the forums here.
« Reply #4 on: December 04, 2017, 08:19:29 PM »
TV Series scraping from tvdb has been fixed on the X3D Series :)
Please follow this procedure before you scan TV Series
1. Delete all xml files in a TV Series where you had added episodes that had no images
2. Delete all zero sized jpg images in TV Series where the image did not show
3. Reboot the Mede8er and it will automatically update the scraper app
4. Scrape TV Series in the normal way
Offline Chiellie25
« Reply #5 on: December 06, 2017, 11:23:40 AM »
This is good news that the TV Scraper is fixed.
Thanks for the help in this.
Rgds, Chiellie25
Offline mike_carton
« Reply #6 on: December 06, 2017, 04:40:15 PM »
So, this is not a new firmware version?
« Reply #7 on: December 06, 2017, 08:12:58 PM »
The scraper code is downloaded on every boot if you accept the scraping aggrement. It had to be separate to ring fence it from paid for code. Otherwise a bussiness licence is needed.
