for avoiding other suggestions, try to connect with composite cable (yelow + red and white) and try it in this way.
if is ok switch M8R TV SYS to a fixed output resolutiion like 1080p 50 hz, then switch back to hdmi connection.
it is very possible that , by mistake, you touch the tv sys button from remote and change the output to hdmi auto or to a unsupported one.
