Pages: [1] 2   Go Down
Author Topic: [TIP] Mede8er beginners guide  (Read 15595 times)
« on: December 31, 2009, 12:48:03 pm »
Mede8er beginners guide (firmware version 3.0.4)
(this is a 'living/growing' document)
Placing and connecting your new Mede8er:
First read the included User Manual and Multi Language Quick Start Guide
It explains how to connect the cabling, insert a HDD if you've purchased one separately and gives some explanation about basic operation.
When you have read the manual you are ready to connect it and play.
First make sure you place your new mede8er in a well ventilated spot.
Avoid placing it in a closed cabinet.
There should be enough airflow to cool your equipment otherwise it will become defective.
Also be careful when stacking several devices on top of each other, this could also heat up your equipment and eventually brick it.
Connecting the cabling:
 o Connect it to your TV with supplied HDMI, or if not available using the supplied RCA cables as described in the Quick Start Manual;
 o If you use a separate A/V receiver or amplifier for audio, you can connect that by a coax digital cable or a optical digital cable. If you have a receiver with HDMI inputs then that is not required if your audio set is also connected via HDMI cable to another HDMI connection on your TV;
 o Connect a wired (UTP) network cable if you want to use network functionality.
Now you are ready to power up your Mede8er.
Starting up your Mede8er for the fist time:
Be sure you have set your TV to the right auxiliary input (HDMI or analogue AV depending on what you are using)
Now press the power switch. Your Mede8er will power up, blue led goes on.
You will see the Mede8er logo on the screen. After some 10-15sec it is fully powered up and you should see the startup screen to choose your language and configure your network connection. Set this as desired - if network cable is attached then choose DHCP, otherwise cancel.
If you don't see anything on your screen, don't panic:
 - First check if you have selected the right input on your TV.
 - If that is OK, then press 1x on the TV Out button on your Mede8er and wait 10 secs. If you don't get output on your TV, repeat this step again until you get output on your screen. You can also use the TV SYS button on your remote control, this has the same function. By doing this procedure you will skip through all the different video modes of the Mede8er until it is set to a mode your TV set recognises, resulting in output on your screen.
Now you are ready to configure your Mede8er.
Go into the System Setup Menu from the Home screen.
Browse to it with the arrow keys on your remote and confirm with the ENTER button in the middle of the arrows.
Now go to the System Setup menu and select System Info. On this screen make a note of the Software Version. If it is not the latest version, then we need to update it.
If you have a hard disk installed or it was pre-installed, check also HDD free space: if it contains no value, the HDD needs to be formatted. It is recommended to always format your HDD from the Mede8er Setup before you start using it in order to be able to make use the full Meder8er features and functionality; this will also prevent instability caused by improper format.
Formatting your internal Mede8er disk and updating to latest firmware version:
Overview of V3 new features.
Now format your internal disk from the same setup menu. Select HDD format menu and confirm the format questions. ALL DATA ON THE DISK WILL BE DELETED.
When the format is finished, the Mede8er will ask to reboot. Confirm this.
If your Mede8er is not on the latest Firmware Version (Software Version), then now is the time to update it to the latest version. You can find the latest version here: Latest Firmware
NOTE: please read the release notes carefully. Currently there is an issue with the 2.0.x versions firmware with mede8er configurations that have no internal disk.This problem is fixed in version 2.1.0 and higher.
Extract the downloaded firmware to a USB flash stick and follow up the attached update instructions carefully. Unpack the zip-file or rar-file. Be sure to place the install.img file on the root of your USB stick, preferably freshly full formatted before using it for the update.
After the update has finished, always do a hard reset by unplugging the DC jack on the back, wait some 20 secs and plug it in again.
Now you are complete ready to set up your video, audio and network.
System Setup Menu
o Audio setup menu
o Video setup menu
o Network setup menu
o System setup menu
o Misc setup menu
If you have an internal disc in your mede8er the best way to organise your media files:
Just create some main folders on the disk, e.g. a folder Movies, Photos, Music.
And then under these folder you create sub folders for each separatie Movie, etc.
With TVIXIE or YAMJ you can create nice about.jpg movie description files in each movie folder. These files will be then visable in the preview window when browsing over your sub folders. When pressing on Slow on the remote control, you can "zoom in" to these movie descriptions.
Note: The Tabs on top of the screen in the Media Library menu are just filters and no folder tabs.
(following sections TBD....)
Basic functionality
o Media Library Menu
o Internet Radio Menu
o File Manager Menu
o Remote Control Functions NEW
Technical questions? Please look at the Technical support guidelines before posting them in the Technical Issue section or the Bug Report section. Good problem descriptions give fast answers.....
Frequently Asked Questions
[SETUP]
o Howto wipe the internal disk if formatting is not working / reset your mede8er with internal disk to start setup complete over from beginning
o I am not able to format my internal HDD in version 2.0.0 or 2.0.1 or 2.0.2
o Howto check if your internal disk is formatted from Mede8er menu
o Firmware recovey emergency upgrade procedure
o Where to find the latest available firmware version
o When should I use the 1080p 24hz option
o Connecting your Mede8er with supplied USB cable to your PC to copy files to the internal disk
o Mede8er MED10WF WiFi Dongle Quick start guide NEW
o Howto setup network connection from Win 7 PC to Mede8er (Samba/Filesharing mode)
o Howto setup network connection from Win Vista 32 PC to Mede8er (Samba/Filesharing mode)
o Howto setup network connection from Win XP PC to Mede8er (Samba/Filesharing mode)
o Howto setup network connection from Mede8er to PC (Samba/Filesharing mode)
o Howto setup network connection from Mede8er to NFS server on PC
o Howto setup NFS on the Mede8er
[GENERAL USE]
o Howto make a play-list
o Mede8er supported video codecs and audio codecs
o Where to download Media Info to check file video or audio codec
o Copy over network. Howto increase speed
o Howto convert a DVD TS structure to one iso file NEW
[CUSTOMIZING]
o Creating nice movie description backgrounds with "scraping" tools  TVIXIE or YAMJ  NEW
o more to come...
I hope this beginners guide is useful for all those new Mede8ers here on the forum.
Please give a reply to this post if you like it or what improvement you like to see.
Expressions of compliments are ofcourse also welcome  Wink
To the more experienced members over here:
If you have material to add to this Mede8er beginners guide, or other good remarks to make the contents better, please feel free to reply with a post with that contents to this beginners guide. If it really contributes, I will add it.
Cheers,
« Last Edit: July 21, 2010, 01:18:18 pm by Maasbommel » Logged
Panasonic SA-PTX5
Ormbett
Full Member
« Reply #1 on: December 31, 2009, 01:08:53 pm »
I am impressed, nice work Maasbommel!  Smiley
Kind regards
Ormbett
•250ml water (cold or soda water)
•200g flour (325 ml)
•400 ml heavy/whipping cream
•butter
Serve with cloudberries and whipped cream!
Jark
« Reply #2 on: January 01, 2010, 03:42:05 pm »
Maasbommel, thanks for this guide.
I bought my player  (incl. intern 500GB) yesterday at Mediamarkt and this evening I will connect it to my tv.
Jark
****GELUKKIG NIEUWJAAR!!!****
chadm
« Reply #3 on: January 02, 2010, 09:56:32 am »
Hi Maasbommel,
This is BRILLIANT thanks for the effort put in to put this comprehensive guide together... pity it is so hidden away from the new user who want to get going ASAP.
I think this should be put in the Mede8er Publicity section so all Newbies just arriving won't miss it. I am sure that given this there will be a lot less people makin blunders when they first setup.
Regards
Chad
« Reply #4 on: January 02, 2010, 02:25:10 pm »
Hi Chad,
Good suggestion. There is now also a message in the Announcements section.
Hope people can find it faster now.....
Cheers,
Panasonic SA-PTX5
beartiger
« Reply #5 on: January 04, 2010, 11:22:30 am »
Is it worth compiling all of this info in to another easily downloadable pdf file similar to the quick start guide also?
beartiger
Mede8er MED500X (HDMI Video & Coaxial Digital Audio Passthrough)
Pioneer VSA-E03 Dolby Digital 5.1 AMP
Panasonic Viera TX-P37X10B 37" Plasma TV
Devolo HD 200mbps HomePlug Network
« Reply #6 on: January 04, 2010, 01:32:43 pm »
beartiger
Thanks for your suggestion.
This Mede8er Beginner Guide is supposed to be (and stay) a "living" document, if I make a .pdf document of it, it will become a fixed content that is not easily to update with all the links in it.
My guess is that it will never be "finished", because of more Mede8er features will come with new firmware in the future.
So I think that a pdf  format document will not be very practical to keep up-to-date.
If people want to make a hardcopy of it, they can print this pages and put it somewhere next to the Mede8er also.....
Panasonic SA-PTX5
cleintje
« Reply #7 on: January 06, 2010, 12:35:40 am »
Thanks Maasbommel.
Yesterday I bought my player with intern 1TB . Tomorrow the postman will bring it. Can't wait to follow the instructions.
Keep up the good work!!
Cleintje
« Reply #8 on: January 06, 2010, 12:38:09 am »
Hi Cleintje,
Welcome to the Mede8er community and a lot of play pleasure with your new Mede8er.
Cheers,
Panasonic SA-PTX5
cx4gunman
« Reply #9 on: January 09, 2010, 11:34:39 am »
Wow Nice work Maasbommel !!
Thanks.
*Lav*
« Reply #10 on: January 12, 2010, 08:17:30 pm »
that firmwire is bomb Tongue everything is work fine..and nice..im really happy that i purchased ur product Grin
be2716
« Reply #11 on: January 18, 2010, 08:59:22 pm »
This will help tomorrow when I will get mine.
« Reply #12 on: January 18, 2010, 09:29:32 pm »
Hi be2716,
Thanks and welcome to the Mede8er community  Smiley
Cheers,
Panasonic SA-PTX5
Sparkie84
« Reply #13 on: January 21, 2010, 03:58:30 pm »
Hello guys, Another Newby!  Smiley
I found and joined the forum after I purchased and tried out my Mede8er for the first time this weekend and am pleased to see that a couple of issues I had (Like HDD Size reporting and Internet Radio) are already addressed with the new Firmware version. Thanks for this great beginners guide.
I will be applying that tonight and am looking forward to witnessing all the features tip top.
Am loving the unit so far and how it can be made personalised so well.
I'm sure I'll have some questions at some point and hope I can help with some before too long too.
Regards
Sparkie
Mede8er Ver 2.0.2  (1 Upgrade from 1.2.1)
1.5TB Samsung HD154UI EcoGreen SATA, Formatted by Mede8er Ver 1.2.1
100bt LAN  to Vista Dell 2.8Ghz Duocore PC (4G Ram) via Thompson ST330 Router
RCA Output to Scart on Standard 14” TV -  (Temporary Arrangement)
« Reply #14 on: January 21, 2010, 10:17:00 pm »
Hi Sparkie84,
Welcome to the mede8er community.
Cheers,
Panasonic SA-PTX5
Pages: [1] 2   Go Up
