I'm using a Logitech K400 keyboard with my MED1000X3D and it does work but I'm having issues with some of the buttons and would like to know if others using the K400 with the 1000X3D have had these same issues.
Specifically, do the function buttons work? How are you getting them to work? Is there a button that can be used to fast forward, pause, rewind, etc.? Does anyone have a diagram or document showing how they've mapped the 1000X3D's remote functions to the K400 keyboard?
Also, can you get any response from the K400's trackpad on the X3D? Last but not least, what version of the firmware are you using on the 1000X3D if you have everything functioning properly with your K400?
Thanks in advance!
