Author Topic: upgrade problems - please help!  (Read 1385 times)
Offline AntonFouche
« on: November 13, 2016, 02:00:57 PM »
Hi everybody. I'm new to the forum and please ask advise regarding my MED1000X3D
I brought it in 2012 and its been awesome, lately some of the MKV files only played the audio so I decided to upgrade the firmware - from V1.0 to V4.0.2
I followed the instructions in the manual and it started installing (perfect so far).  However it never restarted :(
I then followed the "emergency method (resets config to default) but alas... nothing
only the "8" logo comes up and it just hangs... switched it off and on, following the instructions again but still nothing
Does anyone have an idea what I can do next?  Thanks Anton
Re: upgrade problems - please help!
« Reply #1 on: November 13, 2016, 04:54:18 PM »
Install the bootloader upgrade first...jan2013. The link is in the fimware release thread you used.
Then reinstall the latest firmware
« Last Edit: November 13, 2016, 05:20:03 PM by jer1956 »
