Author Topic: How to set up NFS shares in Windows 2012 that works with mede8er  (Read 15201 times)
Offline NotValid
« on: February 09, 2013, 12:23:16 AM »
I need some help setting up my NFS shares on my windows server.
As of now I have set up NFS with anonymous accesst the mede8er see the shared folder , but subfolder/ content of the main NFS is not shown- I do not know what Im missing.
NotValid
Storage freak, 68 TB of HDD space.
Mede8tor1000X3D, Yamaha RX - A3010 AVR, Sunfire Grand Cinema, OPTOMA HD300X, All cisco network.
Offline couto
Re: How to set up NFS shares in Windows 2012 that works with mede8er
« Reply #1 on: February 09, 2013, 01:34:47 AM »
NotValid
admin read / write access ?
see this tutorial for whs 2011
http://www.mediasmartserver.net/2011/12/23/guide-setting-up-nfs-in-whs-2011/
« Last Edit: February 09, 2013, 01:42:45 AM by couto »
Med1000X3D
Anthem MRX-310
Mitsubishi HC5
LG Oled 1080P
100 inch screen
Router. Linksys E4200
Protocol : UDP 32K
Media Files:ISO 3D, MKV, FLAC
Offline NotValid
« Reply #2 on: February 09, 2013, 02:24:00 PM »
I is actually the same way that I'm doing it now, still not possible to see the content of my shared folder.
Thanks for the info anyway
Notvalid
Offline jstaylor
« Reply #3 on: February 11, 2013, 09:09:24 PM »
I'm having the exact same issue.  I'll circle back if I figure anything out.
Offline NotValid
« Reply #4 on: February 14, 2013, 02:05:01 PM »
That would be excellent. I think I have a lead on why it is like this tho. I think its necessary to install  identity management for unix that will require DC  ...including DNS ...  if you figure out another way let me know.
I havent tried this yet... but I might have to to get this to work.
I got it to work, but you'll need the above... its a pain. And its not 'recommended' to run DC and DNS on your storage server... but you can... and then u can share NFS from windows server 2008 / 2012
Notvalid
« Last Edit: February 14, 2013, 03:53:44 PM by NotValid »
Offline jstaylor
« Reply #5 on: February 15, 2013, 07:57:05 PM »
So, I already have a domain controller in my home network.  It is in another box that hosts the domain and is also my Exchange server.  So, what exactly did you have to do with UNIX Identity Management to get it to work?  Thanks for your help!
Offline NotValid
« Reply #6 on: February 16, 2013, 05:40:13 PM »
I made a user and gave him an UID and GID ... 500 on both. So when I shared the folder i shared by using UID and GID... value 500.. then it worked ..
NotValid
Offline jstaylor
« Reply #7 on: February 28, 2013, 09:56:04 PM »
Hmm, I'm still having issues.  I used my main username and on the DC I assigned  a UID and GID of -2.  I then shared folders using NFS server and designated the same UID and GID.  I can still see the top level folder, but nothing below.  I also tried using a UID and GID of 0.  Is there something special about the UID and GID of 500 that you chose to use?  It is frustrating because my wife's Macbook can connect via NFS and see everything fine.  Ideas?
Offline Mike42
« Reply #8 on: March 01, 2013, 07:05:15 AM »
For nfs setup check this thread:
http://www.mede8erforum.com/index.php/topic,10625.0.html
Wokrs perfectly
Gr, mike42
Mede8er : MED1000X3D
Network: Wired CAT5
AV receiver: Onkyo TX-NR414
additional equipment:
Offline jstaylor
« Reply #9 on: March 01, 2013, 07:16:40 PM »
I realize I can install Windows 7 and HaneWIN and use those settings and it will work fine.  The entire point of this thread, however, is to get NFS working with Windows Server 2012.  I may just give up and go the HaneWIN route for simplicity, however.
Offline NotValid
« Reply #10 on: March 02, 2013, 03:26:47 PM »
Hanewin wont run on windows server 2012 unfortunately.
Offline NotValid
« Reply #11 on: March 02, 2013, 03:28:16 PM »
Im not sure what -2 does, but my shares worked perfectly when i used UID=GID=500
Notvalid
pisti7204
  • Guest
« Reply #12 on: April 12, 2013, 08:56:53 AM »
after one week of trying different solutions on my HP Microserver with Windows 2012 Essentials i have found a solution!
The integrated NFS server in Windows 2012 is a useless piece of [CENSORED]! I can read and write NFS shares from Mac OS 10.8.3, but my MED600X3D can see just shared folder header but nothing inside the folder...
One and only 3rd party solution is Allegro NFS for me. You can download 30 day trial from here (the full version costs 65 USD):
http://www.nfsforwindows.com/home
Very easy set-up, small, and WORKING!  Befor installing don't forget to uninstall any other NFS servers and services.
Offline NotValid
« Reply #13 on: May 04, 2013, 04:27:11 PM »
The problem with 2012 essentials is that it uses the light version of AD = LDAP. You have to use unix management rights to let the mede8ter connect successfully to the server... in other words you need a full version of windos 2012 server.
But I agree with you ... it was a pain in the neck to get that to work aswell....
Offline Letiteuf55
« Reply #14 on: January 06, 2017, 03:47:44 PM »
Hi guys, i'm sorry to reopen this very old topic but i have the same issue and found nothing about that...
I've setup a NFS share folder on my Windows server but i'm only able to see the shared folder but not the subfolder inside... i'm so lost...
Thanks a lot if you have anay idea...!
this topic has 9000+ view because of google send us on this forum when we search NFS for windows :/
