Author Topic: ripping blu-ray?  (Read 7305 times)
Offline wcronje
ripping blu-ray?
« on: January 16, 2010, 10:00:41 am »
hi - i have managed to place most of my standard def dvd's onto my mede8er with plenty space to go. i would like to do the same with my blu-ray's and cannot seem to find a proper ripper that can do it in a couple of simple clicks without running into copyright issues the whole time.
i have tried:
handbrake, moyea blu-ray ripper (works on some, newer copy protection makes it fall over/asks to email for support the whole time), Slysoft, Super C, Best HD BD converter/ripper, Pavtube - yip, tried them all and gets errors with new/latest blu's - i.e transformers 2 etc
i am not necessarily looking for something free, if it works well, i will pay for it - no probs.
i have an external blu-ray reader/writer (lg)
anyone with any good rippers for bd?
Offline mysticc
  • B8a Tester
Re: ripping blu-ray?
« Reply #1 on: January 16, 2010, 12:33:54 pm »
V3.0 Beta
MED500X with internal HD 250G
100Mbit Networked with CAT5 to AVM Fritz 7220
Networkshare mainly on Win2003 Server, sometimes on Windows7 x64 Ultimate
Connected via Component to LCD and HDMI to projector.
AVR: Denon-3805
Projector: Sony HW-10
LCD: Viewpia 37
Blu-Ray-Player: LG BD 370
Offline wcronje
« Reply #2 on: January 17, 2010, 06:35:14 am »
tks mysticc - have you/are you using it?
Offline sarje
  • B8a Tester
« Reply #3 on: January 19, 2010, 02:11:51 am »
AnyDVDHD works fine.  It needs updating a lot though as new encryptions are introduced.
It'll only make one to one copies of your discs though.  To compress, copy movie only or make MKV's you'll need extra software.  DVDFab works great for compression.
V3.04
MED500X with internal HD  Seagate 1.5TB
Shares on XP Pro
HDMI to LCD
Sound via optical to Yamaha 5.1 AV amp
Sinotech 42" full HD LCD
Offline deedas
« Reply #4 on: April 06, 2010, 04:53:51 pm »
I use a program makeMKV which rips any BD to a mkv file. Search for this file in Google and install. Very simple to use
Offline mysticc
  • B8a Tester
« Reply #5 on: April 06, 2010, 05:01:42 pm »
Or for some advanced converting look for BluRip or BR-Rebuilder.
BR-Rebuilder shrinks a complete BR to a new BR for DVD5 or DVD9.
V3.0 Beta
AVR: Denon-3805
LCD: Viewpia 37
Offline Nielson
« Reply #6 on: April 06, 2010, 06:52:18 pm »
Try using Ripbot 264, it works brilliantly for me on normal DVD's. Haven't tried it for Blu-ray but it does support it.
Offline getafix
  • B8a Tester
« Reply #7 on: April 07, 2010, 08:32:18 am »
Is Slysoft the only encryption removal tool around ot are the any good free ones?
Mede8er: MED500X  with firmware 2.0.2
Audio: Digital
Video: HDMI passthrough - 24hz off
Network: CAT5
Router: 10/100 Huawei B970 - Static IP
Display: 47" LCD Full HD connected via HDMi
HDMI connected to Yamaha RX-V2065.
PC's: AMD Phenom quadcore with Win7 64 bit.
Streaming: Via NFS with Hanewin
Movies: All ripped to .ISO
Music: mp3 @ 320kbs
Requests: Incorporate YAMJ into firmware.
Offline Ormbett
  • B8a Tester
« Reply #8 on: April 07, 2010, 08:37:50 am »
Dont know if its any good but it seems to be free
http://free.blu-ray-decrypter.com/
Kind regards
Ormbett
•250ml water (cold or soda water)
•200g flour (325 ml)
•400 ml heavy/whipping cream
•butter
Serve with cloudberries and whipped cream!
Offline Nick
« Reply #9 on: April 07, 2010, 11:39:00 am »
DVD43 is free and works well for DVD's. Not sure about BD but you can try it.
http://www.dvd43.com/
Offline wcronje
« Reply #10 on: April 08, 2010, 10:29:37 am »
tried makemkv - to test it i tried ripping transformers 2 (bd), the universe (bd) - does not work!
