Author Topic: Med1000X3D 3D BDISO Play Back  (Read 42592 times)
Offline Heino
Re: Med1000X3D 3D BDISO Play Back
« Reply #30 on: January 05, 2013, 12:27:27 PM »
Vielleicht ist ja das HDMI Kabel im arsch du schreibst ja selber das es ein Rückläufer ist.
Nee, habe das beiliegende gar nicht genommen, sondern dass vom 3D-BD-Player. Zudem es am 3D-Beamer ja genauso ist. Und hier ist noch ein anderes HDMI 1.4 angeschlossen. Welcher Film genau war es bei Dir nochmal? Lichtmon 1 oder 2? Ich probier das jetzt nochmal mit dem Werksreset. den hast Du doch bestimmt über das Menü gemacht, oder?
« Reply #31 on: January 05, 2013, 12:38:28 PM »
Heino,
Did you already try some factory reset in setup, then not set the red borders in video setup?
Also be sure that BDLight Menu option in setup is off (toggle with F3 button) or straight in the setup menu to verify it is off - otherwise you will run in 2D mode and you might not see true 3D effect but only some simulated thing by your TV.
« Reply #32 on: January 05, 2013, 12:41:03 PM »
I have found on dredd iso it will only play the 2d version , it might be how the disk is authored
I just ripped it in to a 3d mkv with make mkv and it solved the problem
It's a better way to keep the files as well
Look in the tips and tricks to learn how
Nemo works fine on mine if I have bd menu on I get a menu and it plays the 2d version if I have it off the 3d version kicks in
Can you give us a mediainfo text list of that dredd iso?
Offline bazzio
« Reply #33 on: January 05, 2013, 12:46:55 PM »
I also have problems with "minimal" 3d depth. Got the Samsung 46ES8000 this morning and tested some 3D ISO's. If i adjust the 3d settings to maximum on the tv then i see some depth but minimal. With standard settings and trying the 3d explore trailers the 3d effect is how it should be... Also i don't see 3D options in the mede8er menu when playing the file, is this normal? I'm on firmware 1.0.5
Offline toddy28
« Reply #34 on: January 05, 2013, 12:54:05 PM »
Most 3d films don't look like the show off trailers on the Samsung explore trailers , or what you see in the shops
Try journey to the Center of the earth or final destination 5 for that sort of effect
Most 3d is depth , kids films are good for pop out , what have you been watching ?
Offline Heino
« Reply #35 on: January 05, 2013, 12:55:17 PM »
mediainfo is one site back. What do you mean with this?
@Maasbommel
Yes I made it for 2 times. 2 factory resets
Yes BD-Lite is off an I know this feature. If I set BD-Lite on "Off", then the Film shows me only a "Making Of". If I set BD-Lite "On", then the film started with original film menu. Then I klick on "film start" an the film runs in 2D. Then I go to the mede8er menu (on the remote left under the tax-cross) and select Playlis. After then I see a list. I select the mainvideo, TV goes in 3D, picture is blurred, I put my polglasses on, the picture is clear,...but... no 3D. All is okay like 3d must be. But no 3D.
Offline toddy28
« Reply #36 on: January 05, 2013, 12:58:51 PM »
It's a re encode down to 25gb from the original 46gb so not sure it would be much help , the other re encodes I have work ok though ,
Offline toddy28
« Reply #37 on: January 05, 2013, 01:08:33 PM »
@Maasbommel
Please try another 3d iso you should not need to select any 3d modes it should just play , going through the bd lite menu will only give you fake 3d from the 2d film , if you select 3d from the players menu
If it works right the 3d film will just start no need to select any 3d options ,
Offline Heino
« Reply #38 on: January 05, 2013, 01:35:35 PM »
So,..goog news...Lichtmond 2 works fine  :D
But why not Sammy's Adventures and Drive Angry?
Is here someone who owns this movies and can tell me if the movies works fine by you?
« Reply #39 on: January 05, 2013, 01:40:05 PM »
Heino
We have no clue why it does not work but I suggests you try following
http://www.mede8erforum.com/index.php/topic,9624.0.html
« Reply #40 on: January 05, 2013, 01:49:23 PM »
Can you post a mediainfo analaysis:-
http://mediainfo.sourceforge.net/en
I know you may prefer bdinfo, but we can put two mediainfo text lists side  by side  and compare.
Offline bazzio
« Reply #41 on: January 05, 2013, 02:02:04 PM »
I've watched avatar 3d bdremux 25 and Ice age 4 (3D ISO and makemkv version). Like i said it looks strange that the mede8er menu is not giving me 3d options. Also the tv doesn't recognize the 3d on it'own, i need to set it manual on the tv. When starting avatar "3D" pops up in the screen.
« Reply #42 on: January 05, 2013, 02:06:45 PM »
Can you please perform an EDID capture and post the results.
1) Create a folder with name "hdmi_test_dora129.3" on a USB stick (in the root), and plug it into Mede8er
2, Connect the Mede8er to AMP/TV, > (please use HDMI), and set the audio mode of Mede8er to (HDMI passthrough)
3, Enter the Home Page on the Mede8er and ENTER number '1025'
4, You will see messages displayed on the TV, and a file will be written to the folder "hdmi_test_dora129.3" on usb disk.
Another way todo it  (Tested with X3 FW 7 sept 2012):
3, Now play a movie on the Mede8er and ENTER number '0'
4, Now you will see that the usb stick starts flashing and writing the dump in the dora folder. Wait some minutes before unplugging the usb stick, don't pull it when it is still flashing
Offline Heino
« Reply #43 on: January 05, 2013, 02:16:53 PM »
Sorry please, but no *.mkv, .*m2ts. I want only use BD-ISOs. If I use MKV, than I don't need a hardware mediaplayer. My TV also play mkvs without cost. And if I buy a mediaplayer that promise 3D-BD-ISO, than must it work. Also I need HD-Sound with 7.1, too. I look here on my real homecinema with 3D-Beamer and 7.1 speakers. I prever only high quality. Great, great pity, but it is like all mediaplayer...some 3D-ISO-Movies does not work. Really pity. I will send the box back.
Thanks so lot at all and have a nice weekend  ;)
Offline bazzio
« Reply #44 on: January 05, 2013, 02:31:34 PM »
click here
