Author Topic: Med1000X3D 3D BDISO Play Back  (Read 44596 times)
Offline toddy28
Re: Med1000X3D 3D BDISO Play Back
« Reply #15 on: January 05, 2013, 11:35:24 AM »
I have found on dredd iso it will only play the 2d version , it might be how the disk is authored
I just ripped it in to a 3d mkv with make mkv and it solved the problem
It's a better way to keep the files as well
Look in the tips and tricks to learn how
Nemo works fine on mine if I have bd menu on I get a menu and it plays the 2d version if I have it off the 3d version kicks in
Offline toddy28
« Reply #16 on: January 05, 2013, 11:38:43 AM »
What other iso files have you got ?
« Reply #17 on: January 05, 2013, 11:43:26 AM »
This are 1:1 imgages made by AnyDVD HD. These are Full-Real-3d in framepacking. This are true isos. An all films runs from PC (with PowerDVD 12, per HDMI and nvidia 3dtv driver) and from my BD-Player fine. Absolutely no Problems.
What do you mean with "they only need a 4 mb/s internet connection."??? Internet connection is not yet installed on the box. Internet must be installed for 3D??? I don't believe that, or?
aldiyx was the one who tested using Samsungs own player. That is advertised mainly as a player for 3d streamed over the internet.
We really need a mediainfo Text output for one of your iso's.
Offline Heino
« Reply #18 on: January 05, 2013, 11:46:05 AM »
What do you need? I repeat, all my Films runs on every own 3D-Devices. Only not on mede8bar. What kind of information do you want? And what is with Mede8er1? Why this m2ts file?
@toddy28
MKV? No one speaks here from mkv. Please read the posting and learn, too.
Once more....all my movies runs on eGreat R300, on PC to TV/Beamer and on my 3D-BD-Player. I'm no amateur.
But this effect I have never seen before. The picture is blurred, the 3D-Glasses make it clear, but without 3D. Helloooo,...it's all alright?
« Last Edit: January 05, 2013, 11:52:29 AM by Heino »
« Reply #19 on: January 05, 2013, 11:46:31 AM »
So you are seeing 3D depth with the small test sample Mede8er1 has sent you?
Then still is the question why you are not seeing 3D effect on a BD ISO and others are.
« Reply #20 on: January 05, 2013, 11:47:27 AM »
Hello Hellooo. Do you want to have a normal discussion or not? Come on!
Offline toddy28
« Reply #21 on: January 05, 2013, 11:53:21 AM »
@toddy28
I did read your post you idiot , all my 3d iso files run apart from dredd 3d I haven't got transformers 3 to try but I took a guess it might be the same thing and it only plays the 2d file
I was just giving you a way to make it work and asked what other iso files you had and if I had the same I would test but
sort it out your self
« Last Edit: January 05, 2013, 11:58:53 AM by toddy28 »
Offline Heino
« Reply #22 on: January 05, 2013, 11:55:36 AM »
Yes, this is the big question.
Sorry, maybe I understand something wrong, because my english is only school english.
« Reply #23 on: January 05, 2013, 11:59:40 AM »
I suggest you try using Google translate. That way you focus on expressing the facts in german, and let google worry about the translation.  That's how we read non english forums posting about Meds, like the links you gave to  a german language forum.
Open it as a second tabbed window in your browser, and you can go  back  and forth quite quickly.
« Reply #24 on: January 05, 2013, 12:03:14 PM »
Hi Heino,
Most of us here are not native English speakers, that is always the difficulty on these forums.
But also understand that a lot are around here just for fun and try to help others out.
If you come in hard, then don't expect from the people they want to invest any further spare free time to help further.
So try to be a bit more careful how you communicate - that is possible with school English.
Are you able to unpack one of those iso files and post some media info output of one of the main 3D streams in it?
That might give some clue what is going on.
Offline aldiyx
« Reply #25 on: January 05, 2013, 12:10:00 PM »
Now i can see 3D Deep and Popouts.
I have do a factory reset and push F3 to switch off BD LIte menu now 3D work´s with Deep and Popouts.
Bei mir geht´s jetz hab den auf Werkseinstellungen zurückgesetzt und die F3 Taste gedrückt mehr nicht ohne Internet.
« Last Edit: January 05, 2013, 12:17:43 PM by aldiyx »
« Reply #26 on: January 05, 2013, 12:11:26 PM »
@toddy28
Heino,  people like toddy28 are volunteering help in good faith. No one is trying to question your abilities. We all learn together here.
Offline Heino
« Reply #27 on: January 05, 2013, 12:15:29 PM »
Sorry, but I'm a litte nervous and stressed. I work yersterday with this box for 6 hpours and today already 9 hours.
Yes of course, I'm able. I have a virtuell drive. Here at first a sreenshot from BD-Info
@aldiyx
Das habe ich auch schon alles gemacht. Hat bei mir nicht funktioniert. Mann, Mann,...was ist das bloß?
Offline aldiyx
« Reply #28 on: January 05, 2013, 12:22:17 PM »
Vielleicht ist ja das HDMI Kabel im arsch du schreibst ja selber das es ein Rückläufer ist. Sonst schick das Ding zurück und gut ist ich war auch schon kurz davor.
Offline Heino
« Reply #29 on: January 05, 2013, 12:24:30 PM »
And here are all infos:
Disc Title:     SAMMYS ABENTEUER 3D
Disc Size:      30.124.803.497 bytes
Protection:     AACS
BD-Java:        No
Extras:         Blu-ray 3D
BDInfo:         0.5.6
Notes:
BDINFO HOME:
  Cinema Squid
    http://www.cinemasquid.com/blu-ray/tools/bdinfo
INCLUDES FORUMS REPORT FOR:
  AVS Forum Blu-ray Audio and Video Specifications Thread
    http://www.avsforum.com/avs-vb/showthread.php?t=1155731
WARNING: Report is incomplete because: Scan has not been run.
PLAYLIST: 00000.MPLS
<--- BEGIN FORUMS PASTE --->
Code: [Select]
        Total   Video
Title                                                           Codec   Length  Movie Size      Disc Size       Bitrate Bitrate Main Audio Track                          Secondary Audio Track
00000.MPLS                                                      AVC     1:25:32 0               30.124.803.497  0,00    0,00    DTS-HD Master 5.1 (48kHz/24-bit)
Code: [Select]
DISC INFO:
Protection:     AACS
BD-Java:        No
Extras:         Blu-ray 3D
BDInfo:         0.5.6
PLAYLIST REPORT:
Length:                 1:25:32 (h:m:s)
Total Bitrate:          0,00 Mbps
VIDEO:
Codec                   Bitrate             Description
MPEG-4 AVC Video        0 kbps              1080p / 23,976 fps / 16:9 / High Profile 4.1
MPEG-4 MVC Video        0 kbps
AUDIO:
Codec                           Language        Bitrate         Description
DTS-HD Master Audio             German          0 kbps          5.1 / 48 kHz / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)
FILES:
Name            Time In         Length          Size            Total Bitrate
00000.SSIF      0:00:00.000     1:25:31.376     0               0
00002.SSIF      1:25:31.376     0:00:01.000     0               0
CHAPTERS:
Number          Time In         Length          Avg Video Rate  Max 1-Sec Rate  Max 1-Sec Time  Max 5-Sec Rate  Max 5-Sec Time  Max 10Sec Rate  Max 10Sec Time  Avg Frame Size  Max Frame Size  Max Frame Time
1               0:00:00.000     0:07:08.511     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
2               0:07:08.511     0:06:20.213     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
3               0:13:28.724     0:10:58.532     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
4               0:24:27.257     0:05:14.981     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
5               0:29:42.238     0:07:09.595     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
6               0:36:51.834     0:08:48.945     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
7               0:45:40.779     0:06:07.575     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
8               0:51:48.355     0:05:06.806     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
9               0:56:55.161     0:13:47.076     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
10              1:10:42.238     0:05:36.377     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
11              1:16:18.615     0:03:41.346     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
12              1:19:59.961     0:05:31.414     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
13              1:25:31.376     0:00:01.001     0 kbps          0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 kbps          00:00:00.000    0 bytes         0 bytes         00:00:00.000
STREAM DIAGNOSTICS:
File            PID             Type            Codec           Language                Seconds                 Bitrate                 Bytes           Packets
00000.SSIF      4114 (0x1012)   0x20            MVC                                     10,886                  0                       0               0
00000.SSIF      4113 (0x1011)   0x1B            AVC                                     10,886                  0                       0               0
00000.SSIF      4352 (0x1100)   0x86            DTS-HD MA       deu (German)            10,886                  0                       0               0
00002.SSIF      4114 (0x1012)   0x20            MVC                                     0,876                   0                       0               0
00002.SSIF      4113 (0x1011)   0x1B            AVC                                     0,876                   0                       0               0
<---- END FORUMS PASTE ---->
QUICK SUMMARY:
Protection: AACS
BD-Java: No
Playlist: 00000.MPLS
Length: 1:25:32
Video: MPEG-4 AVC Video / 0 kbps / 1080p / 23,976 fps / 16:9 / High Profile 4.1
Video: MPEG-4 MVC Video / 0 kbps /
Audio: German / DTS-HD Master Audio / 5.1 / 48 kHz / 24-bit (DTS Core: 5.1 / 48 kHz / 1509 kbps / 24-bit)]/quote]
