Author Topic: Med1000X3D 3D BDISO Play Back  (Read 42590 times)
Offline aldiyx
« on: January 04, 2013, 09:40:02 PM »
I bought a new Mede8er Med1000X3D. The problem I have, the 3D is not really coming out from the TV . The effect is exactly as if it is converted from 2D to 3D but it is a 3D BDISO. This effect an the Picture is not working.
Med1000X3D new FW. 1.0.5
Transformers 3  Blu-ray 3D and other 3D BDISO.
TV: Samsung UE40ES8090 3D HyperReal Engine 2D / 3D-Konvertierung
Can I do somethig or the Med1000X3D must go back to the Dealer.
« Last Edit: January 04, 2013, 09:49:33 PM by aldiyx »
Re: Med1000X3D 3D BDISO Play Back
« Reply #1 on: January 04, 2013, 09:57:01 PM »
If you havn't renamed your files then you have to use the menu to trigger 3d.  3d mvc requires  manual  selection of top on Bottom.
If you don't force 3d by name or menu  you will get 2d.
Offline aldiyx
« Reply #2 on: January 04, 2013, 10:22:08 PM »
i use the menu to trigger 3D and get Shifted, blurred image but no Popouts.
John-Sinclair have the same Problems in this forum.
Re: Re: Re: Med1000X3D 3D BDISO Play Back
« Reply #3 on: January 04, 2013, 10:33:13 PM »
sent by mobile with Tapatalk
Your tv menu or mede8ee menu?
Offline aldiyx
« Reply #4 on: January 04, 2013, 10:49:44 PM »
tv and mede8er menü on 3D
with Samsung „Explore 3D“ App i can see Popouts and Real 3D but with mede8er no Popouts
« Last Edit: January 04, 2013, 10:55:47 PM by aldiyx »
Offline couto
« Reply #5 on: January 05, 2013, 12:01:46 AM »
You must be doing something wrong in your setup.
In 25 x 3DBD iso i have,  there no visíble diferences beetween blu-ray player and x3 players.
If is 3D iso file the x3 auto detect, and so your tv detect 3D, you dont need to use menu, what you can do is swap let /right eye for some 3d movies.
And when you refere 3d samsung explore app, that is 3d streaming from samsung servers, you are missing to tell us whats your 3D iso?
Pop out 3d effect depends of movie and filmaker.
« Last Edit: January 05, 2013, 12:13:25 AM by couto »
Med1000X3D
Anthem MRX-310
Mitsubishi HC5
LG Oled 1080P
100 inch screen
Router. Linksys E4200
Protocol : UDP 32K
Media Files:ISO 3D, MKV, FLAC
Offline Heino
« Reply #6 on: January 05, 2013, 08:00:25 AM »
Hi, I'm John-Sinclair from the hifi-forum, my english is not the best and i can say, that doesn't work.
Switch between left/right does not work and any other setups not, too. I tried really all here for 2 days. I tried it b my Yamaha Receiver HDMI 1.4 Input and also directly by my HDMI-Input from TV. The cable is also 1.4. No 3D-Effects, no Popouts. Even Sammys Adventures doesn't work in 3D. The picture is blurred, the 3D-Glasses make it clear, but without 3D. My TV recognizes 3D, I can use the TV-3D-Settings, but nothing helps. I tried all Aspect ratios from TV 16:9, Auto and Just Scan. I made a hardreset by the box. The same with the settings from the mede8er...also here,...i tried all...nothing. Here is the link from my last posting in hifi-forum. http://www.hifi-forum.de/index.php?action=browseT&forum_id=181&thread=9030&postID=906#906
I use the firm 1.05. Is there any other Firm, that i can try?
PS: Ahh,...that reminds me, I also own a 3D-Beamer from Panasonic. This device I have not tried yet. My last trial.
PS from PS: With the 3D-Beamer doesn't work, too. Now I try,...flash the firm 1.05 again. Maybe it's failed?
« Last Edit: January 05, 2013, 08:29:41 AM by Heino »
Offline bazzio
« Reply #7 on: January 05, 2013, 08:23:45 AM »
Just to be sure... you have switched BD LIte menu OFF?
Offline Heino
« Reply #8 on: January 05, 2013, 08:35:17 AM »
I know. I tried both repeatedly. BD-Lite-Menu "On" = there is an Filmmenue, BD-Lite "Off" = the film started or the Making Of. But nothing in 3D. I muss use the Player-Menu Playbacklist.
Look over you,...I modiefied my last post. Two devices that doesn't work. With different Cables. That can not be. On PC and 3D-BD-Player all works fine. Either the firm is failed or the device is out of order.
PS: Flashing the Firm 1.05 again made nothing. It's the same like before.
I'll send the box back.
A last question,...must I also renamed BD-ISOs? If yes, what must I write?
« Last Edit: January 05, 2013, 09:30:18 AM by Heino »
« Reply #9 on: January 05, 2013, 09:53:07 AM »
Are these "clones" of bd iso's or some rip packaged as an iso?
Are these downloads of Samsungs demo films for streaming?  Those can't be true iso  as they only need a 4 mb/s internet connection.
« Last Edit: January 05, 2013, 09:58:25 AM by jer1956 »
Offline Heino
« Reply #10 on: January 05, 2013, 10:12:24 AM »
This are 1:1 imgages made by AnyDVD HD. These are Full-Real-3d in framepacking. This are true isos. An all films runs from PC (with PowerDVD 12, per HDMI and nvidia 3dtv driver) and from my BD-Player fine. Absolutely no Problems.
What do you mean with "they only need a 4 mb/s internet connection."??? Internet connection is not yet installed on the box. Internet must be installed for 3D??? I don't believe that, or?
Offline Heino
« Reply #11 on: January 05, 2013, 10:32:25 AM »
Internet is install now. It's all the same.
But,...is it possible that I made a wrong firmware update? I made by the menu and not by the EMERGENY RECOVERY PROCEDURE. Maybe,...is that the fault?
« Reply #12 on: January 05, 2013, 10:48:10 AM »
Heino
I send you a PM with a link to a test file. Pls check it and report back.
Offline aldiyx
« Reply #13 on: January 05, 2013, 10:52:25 AM »
i have too no Internet
Lichtmond.2.3D
Transformers_Dark_Of_The_Moon_3D_2011_Bluray_3D
in BDMV\STREAM\SSIF\
00008.SSIF
in the iso i have the ssif Files but i see no Popouts Mede8er is on the Factory Setting i have nothyng change with
the FW 1.0 it was the same. I have from my MED500X USB Wlan Stick would it work with X3.
« Last Edit: January 05, 2013, 11:16:39 AM by aldiyx »
Offline Heino
« Reply #14 on: January 05, 2013, 11:33:06 AM »
I made now a update with EMERGENY RECOVERY PROCEDURE. But it is always the same. 3D does not work.
Attention...I already had the Egreat R300 and all the movies worked perfect that do not work on mede8er. My movies are okay, believe it me. I'm not a beginner.
Remember,...two different devices and by no one the box works fine, btw. works 3D in Framepacking. S-b-S is no problem. But this clear. This works on every Player.
@Mede8er1
First,...thx.  ;)
This movie works, but this is only a *.m2ts and my 3d-movies are all BD-ISO within BDMV and Carificate folder. Your movie is filmed by a camcorder. This is unusable for me. Moreover mede8er advertises with playing Real-3D-ISOs.
But what do you want me to say with this movie?
