Author Topic: Larger Font  (Read 4910 times)
Offline BeenThere
Larger Font
« on: December 23, 2012, 02:13:07 PM »
I bought my in-laws a 300X for x-mas. They have a very old crt tv set (51cm). I choose PAL for TV System setting. The problem is, on that size and type of tv, the fonts are tiny. I tried both the Default A and B fonts, and they are equally bad (from a size point of view). Any way I can get a bigger font? Btw - Running the latest firmware.
Many thanks
Model: MED500X2
Internal HDD: WD WD10EARS-00Y5B1 1TB 3.5" SATA
Network: Wireless
TV: 32" Samsung LA32B530P7RXXA
Audio: Optical to NAD T751 AV receiver
Re: Larger Font
« Reply #1 on: December 23, 2012, 03:22:31 PM »
BeenThere
The modern Media Players are really designed for Higher Resolution Screens and although they work fine on older type CRT screens you may well experience the problem you described.There is no solution to change to other sized fonts other than the options in the GUI itself.
Offline BeenThere
Re: Larger Font
« Reply #2 on: December 23, 2012, 03:38:29 PM »
BeenThere
Thanks for the response. It's a real pity though. People like my in-laws, apart from the fact that they can't see that well any more, can't afford hi-res tv's. I don't see why larger fonts can't be added as an option. I was going to buy my mother a 300X as well, but she also has an old crt tv, so she will face the same problem.
Model: MED500X2
Network: Wireless
Re: Larger Font
« Reply #3 on: December 23, 2012, 04:26:06 PM »
BeenThere
I will ask our engineers if they have a solution for this. Cannot promise anything but its worth a try.
Offline BeenThere
Re: Larger Font
« Reply #4 on: December 23, 2012, 04:35:53 PM »
BeenThere
Nice X-mas present!  ;)
Model: MED500X2
Network: Wireless
