Author Topic: 1.0.5 Problems with NFS  (Read 9196 times)
Re: 1.0.5 Problems with NFS
« Reply #15 on: December 23, 2012, 09:55:12 AM »
I've taken  this NFS problem out of the firmware response post.
What firewall are you using?  I had to manually add both the hanewin console and the service to the windows firewall list of approved apps.
« Last Edit: December 23, 2012, 10:53:47 AM by jer1956 »
Offline usul
Re: Re: Re: 1.0.5 Problems with NFS
« Reply #16 on: December 23, 2012, 01:39:09 PM »
I'm using just Windows internal firewall.
I added both programs to allow list.
Am I entering the information correct to use nfs?
Like using.  /name   for shared folder?
With name being the name I entered in the nfs server?
Weird thing in hanenfs is, when I select modify export string or what ever it's called.
I enter the path where my shares are followed by -readonly -name:name
Then ip of media player.
After I say restart server it does not seem to add the info to window above. Where it gives a summary of what is being exported.
Just leaves that section blank.
On media player I add the ip address of the share computer and use /name for share.
Thanks and hope we can fix this..
Not sure if win 8 is the issue
Sent from my SGH-I747M using Tapatalk 2
« Reply #17 on: December 23, 2012, 01:46:38 PM »
My "exports file" just has V:\nfsshare
We used  to  say  it should have  -readonly before autoview was developed. The manual might not have been updated to reflect that change.
Offline usul
« Reply #18 on: December 23, 2012, 01:50:26 PM »
How do you make the export file apply to program?
When I use hanenfs to edit the default string out does not seem to apply it to program even when I use restart server
Offline usul
« Reply #19 on: December 23, 2012, 01:51:56 PM »
Cool.
Do you need to add ip address of media player at end of string?
« Reply #20 on: December 23, 2012, 01:52:45 PM »
AH..that problem.  You need to give the shortcut Adminstrator Rights, or just Run As Adminstrator. I find it best to change it permently as I also  forget this problem exists.
« Reply #21 on: December 23, 2012, 01:56:08 PM »
Cool.
Not really.  It would be a pain for us as we use so many players to  connect to NFS.
Offline usul
Re: Re: Re: Re: Re: 1.0.5 Problems with NFS
« Reply #22 on: December 23, 2012, 01:59:29 PM »
I will try that again later today.
I know when I entered the number values recommended by the manual I had to run as admin.
Just can't remember if I did when trying to edit the export file within program
Offline usul
« Reply #23 on: December 23, 2012, 02:06:45 PM »
What info do you enter on media player to see this share name?
Does this mean you don't need the -name:
Command?
« Reply #24 on: December 23, 2012, 02:49:08 PM »
currently the auto probe on entering NFS is finding it.
Offline usul
« Reply #25 on: December 24, 2012, 03:44:10 AM »
Just tried you suggestion.and it worked.
I had to uninstall allegronfs to get it to work.
Awesome
