Author Topic: Tv wall app  (Read 26326 times)
Offline JohnWB
Re: Tv wall app
« Reply #45 on: March 01, 2013, 09:00:49 am »
Hi JohnWB,
That screen shot is a preview of what's currently being worked on in the new version.
For now, please follow the tutorial posted at the beginning of this thread.
Thanks,
Zakkie
tx jumiguchi
Thanks for that , will do
« Last Edit: March 31, 2013, 07:39:41 pm by Mede8er1 »
Sony KDL-50W829B, Marantz SR7010, Panasonic BD35, Logitech Elite, Virgin V6, Mission 752, Mission 75C, Wharfedall 9.0, BK XLS200 Mk 2, iPhone 6S, Synology 214Play, Wetek Play2, Mede8er MED600X3D, Amazon Fire Stick, Apple TV2, NowTV, Airport Extremes
Offline jumiguchi
Re: Tv wall app
« Reply #46 on: March 02, 2013, 11:03:04 am »
Hi JohnWB,
Thanks,
Zakkie
tx jumiguchi
No problem. I am glad to help. ;)
Offline Duppie
Re: Tv wall app
« Reply #47 on: March 04, 2013, 03:39:48 am »
Hi Zakkie,
I have removed all my current xml and jpg files and redone it using your beta version, all at once (116 shows):
All xml and jpg files were populated correctly, nice, but during this time TvRename has frozen up 3 times.
I had to force close the app, open it again and redo a scan again, 3 times. I tested this on Windows 7 Pro X64 and run
the app as Administrator. Do not have any issue with initial version.
Thanks for all your efforts. Looks really promising.
Duppie
Offline JohnWB
Re: Tv wall app
« Reply #48 on: March 04, 2013, 10:30:03 am »
Hi Zakkie,
Duppie
Just thought I would mention that I am also using Windows 7 Pro X64 and had no problems at all.
Offline Duppie
Re: Tv wall app
« Reply #49 on: March 04, 2013, 10:36:01 am »
Thanks for the info JohnWB. Did you try more than 100 shows at once?
Duppie
Offline JohnWB
Re: Tv wall app
« Reply #50 on: March 04, 2013, 12:44:34 pm »
Duppie
Just done a quick calc & it would be well over 100 shows at once, more like 180
Offline Zakkie
Re: Tv wall app
« Reply #51 on: March 05, 2013, 08:47:14 am »
Hi Duppie,
Are you still having issues?
I'm also running about 180 shows - 9930 episodes and had no issues with the latest beta.
Regards
Offline Duppie
Re: Tv wall app
« Reply #52 on: March 05, 2013, 09:24:47 am »
Hi Duppie,
Regards
Zakkie,
I will test it again during the week and see if it happens again.
Duppie
Offline pjh777
Re: Tv wall app
« Reply #53 on: March 06, 2013, 09:25:06 am »
what would be really cool is trakt.tv support.
If the app could add files it found to your trakt.tv collection and also based on scanning the .t files send "watched" indicators then this would be brilliant!
Also - I'm not sure if it's people changing the database on tvdb but some episodes seem to get renamed pretty much every time I scan - back and forward between 2 names.
Offline jumiguchi
Re: Tv wall app
« Reply #54 on: March 06, 2013, 10:51:28 am »
Hi pjh777,
It seems to be. But it to be realized by me on the series.
Offline Zakkie
Re: Tv wall app
« Reply #55 on: March 08, 2013, 06:54:12 pm »
503 ERROR
There seems to be a problem with TheTVDB mirrors (which gets all the info for the various scrapers).
Error was sporadic this week but seems completely down for the last few hours.
http://forums.thetvdb.com/viewtopic.php?f=17&t=12874
Regards
Zakkie
Offline Diver73
Re: Tv wall app
« Reply #56 on: March 31, 2013, 06:57:02 pm »
Thanks for this amazing tool!!
