I noticed something today. I just made my first 2 3D BD mkv's yesterday. The first one, The Lorax, was ripped using AnyDVD-HD and then put through MakeMKV. The second one, Tangled, I let MakeMKV process the whole thing. When I went back to play the files today, I noticed that Tangled is showing a split second of "blockiness" in the picture during every scene transition, but The Lorax plays just fine.
I don't know if this means that AnyDVD-HD is doing a better job of ripping 3D-BDs than MakeMKV, or not. Both films are 24fps, so I don't think this is a frame rate issue. Has anyone else noticed this?
I'm using firmware version 1.05 on a MED1000X3D. NSF share with tcp/udp set to Auto and 32k. 1080P 24fps is ON, and Auto Frame Rate is Off.
UPDATE: This issue is probably not MakeMKV's fault. I tried playing Tangled 3D as an ISO (without using MakeMKV of course), and the problem was still there. So it seems the problem must lie with my MED1000X3D or with my network. Also, it seems the split-second blockiness during scene transitions is only visible in the right eye. This may be the same was what mattmarsden was reporting earlier in this thread.
