Author Topic: Makemkv - Extract 3DBDISO to MKV - lots of benefits  (Read 264376 times)
Offline crussader
Re: Makemkv - Extract 3DBDISO to MKV - lots of benefits
« Reply #135 on: March 03, 2015, 09:24:40 PM »
That dosnt meant it converts to MVC.
Doesn't MakeMKV produce the MVC file?
« Reply #136 on: March 03, 2015, 09:40:55 PM »
MVC is the 3d video format used by a bd disk. Makemkv just rewraps the MVC. It dosnt convert other formats to MVC.
For consistency, those rewrapping MVC in MKV wanted an MVC trigger.
« Last Edit: March 03, 2015, 10:13:14 PM by jer1956 »
Offline emma24xia
« Reply #137 on: April 09, 2015, 06:48:50 AM »
MakeMKV works great on extracting 3D Blu-ray disc to MKV, but it does not work for BD ISO so far. So I turned to ByteCopy, another lossless MKV backup tool I find online, what I like best is it copies my Blu-ray to MKV with multiple languages.
« Reply #138 on: April 09, 2015, 06:57:49 AM »
You use something like Virtual Clonedrive to mount the iso.
Offline Johno75
« Reply #139 on: April 13, 2015, 12:58:09 AM »
If I put mvc in the file name of a 3d movie I've made into a mkv using makemkv it won't play he first time I try to play it. I have to stop it and press play again and then it will run properly. If I don't I either get a black screen or scrambled picture etc.
Any idea what I can do to fix it?
« Reply #140 on: April 13, 2015, 07:35:54 AM »
Does it work if you use the old trigger "tb"?
Also makemkv dont keep up with the latest aanti copying techniques.  For some you have to use anydvdhd first, and rip to iso. Then mount the iso and rerip it using makemkv.
If you google about ripping that particuler bd you may get hits on some irritating new anti copying idea.
« Last Edit: April 13, 2015, 07:46:42 AM by jer1956 »
Offline Fmedrano1977
Re:
« Reply #141 on: April 13, 2015, 09:48:49 AM »
Use   name.3DTAB.mkv
HTC One m8
Offline Johno75
Re:
« Reply #142 on: April 17, 2015, 10:23:56 AM »
Use   name.3DTAB.mkv
HTC One m8
the reason why i started using MVC is I asked how do you tell if you need to use TAB or SBS and I was advised to use MVC. So should I just use TAB?
Re: Re: Re:
« Reply #143 on: April 17, 2015, 05:33:15 PM »
Well if your creating MVC MKVs,I don't think it matters which one you use. It's just used to instruct the player your playing a 3D movie and it will automatically detect the mvc mkv and play it as such. 3DTAB is what I use and it's worked flawlessly for me.
HTC One M9
Offline Johno75
« Reply #144 on: April 18, 2015, 07:19:33 AM »
Use   name.3DTAB.mkv
HTC One m8
If I use 3DTAB I still have to start the movie stop it and start it again for it to work properly!
« Reply #145 on: April 18, 2015, 07:52:26 AM »
Is this with every MVC rip?
Offline Johno75
« Reply #146 on: April 18, 2015, 08:16:04 AM »
Offline ZzBloopzZ
« Reply #147 on: September 26, 2015, 06:50:11 PM »
Which tool is best these days, MakeMKV or TSMuxer, and why?
Full ISO back ups are taking up too much space, want to get file size smaller but with best picture quality.
Thanks!
Offline couto
« Reply #148 on: September 27, 2015, 12:00:36 AM »
Thanks!
Ive rip all my ISOs to MKV, the average size drop from 40GB to 25gb p/ file.
Why Mkv ?
Its a format that is compatible with most media players, subtitles, HDaudio trouble free.
Like the 2D the 3DMCV also works well without issues...
My Oppo 103 (cinavia player) plays all the MKVs (except 3D) including all the cinavia Movies from my library....
Also Mkv is Mac compatible...if is the case..
Quality is lossless, because the MakeMKV extract the audio and video track without conversion....the bitrate remains the same..
Med1000X3D
Anthem MRX-310
Mitsubishi HC5
LG Oled 1080P
100 inch screen
Router. Linksys E4200
Protocol : UDP 32K
Media Files:ISO 3D, MKV, FLAC
Offline eentje
« Reply #149 on: October 06, 2015, 10:29:15 PM »
i do the same. Rip bd with makemkv for the filesize and then i use handbrake on it so make it even smaller without any qualilty loss. atleast not that my eyes can see :)
bd 50gb makemkv 25gb handbreake 12gb :) so 4 files instead of 1 ;)
www.thetvdb.com contributor
