Author Topic: Makemkv - Extract 3DBDISO to MKV - lots of benefits  (Read 270064 times)
Offline westham
Re: Makemkv - Extract 3DBDISO to MKV - lots of benefits
« Reply #120 on: December 01, 2014, 01:14:24 PM »
Use the invert left right option on either the player menu, or the TV. Its an expected phenomana, hence why both have it. If it was only a player issue the TV wouldnt have a Menu option for it either.
I just found this thread after doing the same thing myself. MakeMKV (Mac) rip of the Edge of Tomorrow and had to research what was wrong with the resulting rip. Is there any way to get this right in the ripping stage without having to wait until you view the file?
« Reply #121 on: December 01, 2014, 02:18:26 PM »
TSmuxer has  Primary eye option, but I don't have a faulty MKV to  try it with.
You have to  select bluray as the output, and go  to  the top Bluray options.  See what happens with or without using the Right Eye option.
I am just using it for the first time.  In my case it should screw things up if it does anything.
« Last Edit: December 01, 2014, 02:23:37 PM by jer1956 »
Offline westham
« Reply #122 on: December 01, 2014, 02:23:06 PM »
Many thanks I will give it a try.
Any one know how you determine which option is correct (left/right) before you go through all of this or is it trial and error for each disc?
« Reply #123 on: December 01, 2014, 02:26:27 PM »
I think the issue is offiucally MKV supports 3d via mk3d, which isn't for MVC but stereo like SBS.  So it has no field to put the first eye in for MVC. So MakeMKV could see the data in the iso, but has nowhere to  put it.
Since using TAB off the menu triggers MVC processing.....it might be possible to remux MKV to mkv3d stating  its TAB,  and which is first Top or bottom. It could just create an unplayable file.
Did you have the problem with the iso as well?
« Last Edit: December 01, 2014, 02:36:03 PM by jer1956 »
Offline davedipster
« Reply #124 on: December 21, 2014, 09:50:53 AM »
If anyone has issues with DTSMA audio not playing, just choose FLAC as the audio output in MAKEMKV.
dipster
Offline lazostat
« Reply #125 on: January 09, 2015, 09:22:57 PM »
I put a 3d iso to makemkv and i created a mkv, but my tv dont play it like 3d. I can see no over/under or right/left image on the movie..
« Reply #126 on: January 10, 2015, 02:55:14 PM »
That is what Stereoscopic player does on a PC. The X3D is a true 3d player and converts MVC to HDMI framepacked.  All  the TV has to  do is take  each  eye in turn directly from the stream.
Offline crussader
« Reply #127 on: February 25, 2015, 05:10:47 PM »
I am using the latest version of MakeMKV, but I can't find where to make this selection in the menus. Any help?
Offline crussader
« Reply #128 on: February 25, 2015, 06:10:29 PM »
Solved. Have to enable expert mode in the preferences.
Offline Johno75
« Reply #129 on: March 02, 2015, 12:28:05 AM »
hi,
probably a stupid question here but do you know which tab to use in the filename either TAB or SBS? is it film dependent or does it matter which one  you use?
« Reply #130 on: March 02, 2015, 09:45:44 AM »
You can now use .MVC.   The prevois triggers for MVC where those the SDK used via the 3d menu.
Offline Johno75
« Reply #131 on: March 02, 2015, 10:50:21 AM »
Thanks for that. Is that for just for firmwares after a certain revision (as I haven't updated for a while)?
So an example file and now would be
xxxx.MVC.mkv or do you still need 3D in file name?
« Reply #132 on: March 02, 2015, 10:55:09 AM »
http://www.mede8erforum.com/index.php/topic,15654.msg102151.html#msg102151
Item 7.
Offline crussader
« Reply #133 on: March 03, 2015, 03:28:39 PM »
Item 7.
I just found the compelling reason to upgrade my firmware.
« Reply #134 on: March 03, 2015, 03:43:13 PM »
That dosnt meant it converts to MVC.  Its for those who like consistency..and want  to use an MVC trigger name for the MVC files they have ripped.
