Author Topic: Makemkv - Extract 3DBDISO to MKV - lots of benefits  (Read 267680 times)
Offline d2florin
Re: Makemkv - Extract 3DBDISO to MKV - lots of benefits
« Reply #105 on: October 31, 2014, 11:23:47 AM »
Hello ,
  I always select the mvc version the biggest version from the 2 files . After extraction I append in the name of the file : movie.3DTAB.mkv , then the TV automatically detects the 3d header and no remote control button is necessary to press.
   if you do not append 3Dtab you will se 2D and yiu should press 3D button from remote control of tv
  I hope that I answered your question,
 Regards,
Offline mixmix
« Reply #106 on: October 31, 2014, 11:31:57 AM »
Ah ok
So, if my video mkv has only one image like a 2D film, it's normal, I just need activate 3D tv ?
The MKV MVC are only in TAB ? not SBS ?
I've tv 3d active, what the better ?
« Reply #107 on: October 31, 2014, 11:42:32 AM »
Ah ok
TV's can only handle anamorphic...that is SBS or TAB.  Only the player can process MVC as it has to be processed before the HDMI stage from the disk  format to HDMI frame packed.
Offline mixmix
« Reply #108 on: October 31, 2014, 11:52:45 AM »
So the MVC is processed by the MED and the 3D option is enabled on the tv?
« Reply #109 on: October 31, 2014, 12:25:10 PM »
3d on the TV is created 2 ways.
1) it takes the tab or SBS and creates the alternate frames for it self...if you activate 3d on the TV when it asks.
2) it switches to 3d display ( not 3d processing)  automatically when it gets HDMI frame packed 3d from the source. The player will create frame packed output for SBS and tab as well if it processes those formats.
« Last Edit: October 31, 2014, 07:05:15 PM by jer1956 »
Offline mixmix
« Reply #110 on: October 31, 2014, 12:29:28 PM »
Thank you I will test it  :)
Offline cniedzi
« Reply #111 on: November 13, 2014, 08:56:17 PM »
I've got a problem with creating simplified version of full 3DBDISO image (MVC 3D).
1. In the first step I've make MKV (MVC 3D) containing only choosen audio streams and subs using MakeMKV - X3D recognizes it as 3D movie and plays it fine.
2. Then I've created new 3DBDISO from above MKV using tsMuxeR - X3D doesn't recognize new 3DBDISO as 3D movie and plays it as 2D....
Please find below details of:
- original full 3DBDISO: https://imagizer.imageshack.us/v2/689x519q90/661/8PND4t.jpg
- new 3DBDISO:
https://imagizer.imageshack.us/v2/689x519q90/673/LsN2gy.jpg
https://imagizer.imageshack.us/v2/440x529q90/912/f2Mmv1.jpg
What's wrong?
Offline cniedzi
« Reply #112 on: November 15, 2014, 03:58:33 PM »
any ideas?
« Reply #113 on: November 15, 2014, 05:23:37 PM »
Use the iso option in tsremuxer, not ts.
You load a playlist, not ssifs manually, into tsmuxer.
Thera are many online guides for tsmuxer. Try the slysoft forum.
If you do look in the ssifs folder, identify the largest file. Its number will be the 3d playlist. So find the playlist with that number and open it in tsnuxer.
Rember, the subtitle issue is not that makemkv loses the depth, its that the player ignores it with mkv. So its easier to make the MVC mkv, and then open that in tsmuxer. That bypasses the whole playlist problem, and creates an iso which will use the depth information inherited from the mkv.
« Last Edit: November 15, 2014, 07:01:27 PM by jer1956 »
Offline cniedzi
« Reply #114 on: November 15, 2014, 10:45:39 PM »
Thx for reply. It was actualy ISO option choosen to create 3DBDISO (attached screens show only content of new created ISO and therefore ts option doesn't matter). New ISO was created in tsmuxer by loading MVC MKV created with MakeMKV - exactly the way you depicted - so the strange issue is it doesn't play...
« Reply #115 on: November 16, 2014, 08:45:08 AM »
What about the original 3d iso?  If you have Bd Menu on, 24/23.976 is disabled when playing iso, so MVC is impossible. MKV would not have that problem.
Only those making simple camcorder menus should turn it on as required.
« Last Edit: November 16, 2014, 09:20:27 AM by jer1956 »
Offline cniedzi
« Reply #116 on: November 16, 2014, 12:16:10 PM »
Strange... original 3D ISO (MVC) is playing perfectly in 3D and I have BD Lite menu on (because of my home made BDs)
« Reply #117 on: November 16, 2014, 03:44:39 PM »
Do  you have Resume Play on?  If you played any before putting Bd Menu on then the Resume Data could trigger MVC. Any new ones wouldn't start with Bd Menu on, which is the problem  your saying you have with your new 3d ISO.
Offline Wyerd
« Reply #118 on: November 20, 2014, 04:01:02 AM »
New Mede8er user here. I've ripped Edge of Tomorrow to a MVC MKV and called the file Edge of Tomorrow (2014).3DTAB.MKV
The 600x3d plays it in 3D automatically, but the image makes me feel sick until I turn the 3D glasses upside down! So it looks like something has transposed the image for the correct eye. Would this be MakeMKV or is it something to to with the x3d or the file name?
The original BD plays fine using a Samsung BD player to a Panasonic Projector.
Any suggestion where to start looking?
Thanks.
« Reply #119 on: November 20, 2014, 09:12:01 AM »
Use the invert left right option on either the player menu, or the TV. Its an expected phenomana, hence why both have it. If it was only a player issue the TV wouldnt have a Menu option for it either.
