Author Topic: M8 Remote for iPhone / Ipad  (Read 16678 times)
« on: November 15, 2012, 04:27:15 pm »
The M8 Remote for Iphone / iPad is back on the App Store http://www.m8remote.com/
This is a real nice app as it uses screen swipe gestures for navigation. We are in contact with the developers of this app and we are talking to them about adding some additional functions and hope these will be released in some future update.
« Last Edit: November 15, 2012, 07:29:51 pm by Mede8er1 »
trunkdog
  • Guest
Re: M8 Remote for iPhone / Ipad
« Reply #1 on: December 19, 2012, 08:43:01 pm »
Very convenient! It took me a sec to figure out to Dbl Tap the OK button and swipe for the directional arrows but watch out now!
And again I'll use this opportunity to ask...
How do I refresh the Media Lib folder list?
Offline Securityfreak
« Reply #2 on: January 02, 2013, 03:42:52 pm »
Hello,
Does the TV needs to be on when using the M8 Remote app?
I'm searching for a solution were I can stream my music from my Synology by using an app on iPhone/iPad and don't have to put on my TV. (Synology -> Mede8er -> Marantz receiver)
Thanks!
« Reply #3 on: January 02, 2013, 03:48:22 pm »
If you have a version with DMR than you can try this:-
http://www.mede8erforum.com/index.php/topic,6695.0.html
You  need to find an Apple DLNA DMC.
Re: Re: M8 Remote for iPhone / Ipad
« Reply #4 on: January 02, 2013, 05:10:37 pm »
Did you try DS Audio app from Synology?
sent by mobile with Tapatalk
Offline eentje
« Reply #5 on: January 02, 2013, 06:29:50 pm »
Hello,
Thanks!
i bought a compatible usb sound card.. plugged that into my synology and my reciever and voila :) the usb sound cards are around 10-15 euro :)
the official remote is like 90 :P
www.thetvdb.com contributor
Offline ozsolt
    • Company website
« Reply #6 on: April 04, 2013, 08:31:20 pm »
As Maasbommel wrote, use the Synology DS Audio app, it works perfectly with the Mede8er!
Mede8er distributor - Hungary
DENON AVR, Synology NAS, every Mede8er X3D model
Offline ozsolt
    • Company website
« Reply #7 on: April 04, 2013, 08:34:08 pm »
i bought a compatible usb sound card...
Yes, but maybe he needs a better sound quality, like these cheap USB cards can give, and I think, the most people use his NAS far away from his hifi amplifier. So, if he has a Mede8er and a Synology, plus an iPhone, the DS Audio is the perfect solution.
Offline JohnWB
« Reply #8 on: May 22, 2013, 07:28:51 am »
M8 Jukebox now in iTunes
Sony KDL-50W829B, Marantz SR7010, Panasonic BD35, Logitech Elite, Virgin V6, Mission 752, Mission 75C, Wharfedall 9.0, BK XLS200 Mk 2, iPhone 6S, Synology 214Play, Wetek Play2, Mede8er MED600X3D, Amazon Fire Stick, Apple TV2, NowTV, Airport Extremes
Offline Se7en
« Reply #9 on: July 20, 2013, 04:48:39 pm »
Hi  I have purchased the m8 ipad iOS app,
However after initially working on a mede8er 1000x3d it does not work on 800x3d.
I have tried killing the app and restarting, re-downloading the app, resetting router nothing seems to work regarding the resetting of jukebox being able to see movie info and albums etc.
I have spoken with numerous mede8er forum members and the most plausible idea is the cache for jukebox is not clearing?..
Is there a way where the user could implement clearing of cache on exit of program etc?...
Or any ideas why I now can't see the jukebox via favourites?
Cheers
Offline alexARC
« Reply #10 on: December 20, 2014, 09:41:40 am »
Hello,
Thanks!
Hi, pretty much the same here though I would like to play internet radio without having to turn on my videoprojector.
Thanks for your help
« Reply #11 on: December 20, 2014, 09:55:02 am »
That is not what remote emulators do. You interact with the GUI the same way as with the real remote.
What you need is a Smart Remote App, where you interact with the screen on the controller. Unfortunately the api for that only controls jukeboxes.
« Last Edit: December 20, 2014, 10:01:06 am by jer1956 »
Offline alexARC
« Reply #12 on: December 20, 2014, 12:41:20 pm »
Thanks! I have downloaded M8 jukeboxe but indeed, it doesn't work with internet. Pity that we cannot get the full interface on iPad...
« Reply #13 on: December 21, 2014, 02:38:51 pm »
Android users can stream xialive to the dmr using bubbleupnp
