Author Topic: Login fail  (Read 3348 times)
Offline jc76
Login fail
« on: November 13, 2012, 07:26:48 PM »
i will on my external hdd on the pc with network freebies.
when i give the user and password in the fields then come ever logon fail?
Re: Login fail
« Reply #1 on: November 13, 2012, 07:35:55 PM »
jc76
1) I suggest you update to today's release  http://www.mede8erforum.com/index.php/topic,9412.0.html
2) Type in the User Name and  Password each time manually and do not use the stored history on the right side of the Virtual Keyboard
Offline jc76
Re: Login fail
« Reply #2 on: November 13, 2012, 08:21:43 PM »
ok update is on mede8r but dosenīt work and the user and password are simpel!
what can i do?
jc76
