Author Topic: External USB 3TB /4TB Compatibility with X2/ X3 Series  (Read 98583 times)
Offline millo2014
Re: External USB 3TB /4TB Compatibility with X2/ X3 Series
« Reply #60 on: January 29, 2014, 02:20:17 PM »
Seagate Expansion Desktop 4TB USB 3.0 (STBV4000200) works fine with MED600X3D.
Offline fits79
« Reply #61 on: January 29, 2014, 02:27:19 PM »
To mine western digital green 4tb and formatted as ntfs gpt DOESN'T SEE IT with anything i try....
And i DIDN'T FIND ANY SOLUTION AT ALLL...
The model that DOESN'T SEE AT ALL THIS MEDIA PLAYER IS WD40EZRX.
If anyone has this hard disk and find a solution to see it this media player please tell it to me.
I try even with completely deleted and unformatted still doesn't see it.
SO.....
« Last Edit: January 30, 2014, 12:45:10 PM by fits79 »
Offline Irving.Zisman
« Reply #62 on: February 25, 2014, 02:17:41 PM »
Which player model do you have and how do you connect the HDD?
Offline fits79
« Reply #63 on: February 25, 2014, 02:43:22 PM »
I fix it by put the 4tb hard disk into a pc and make it shared with the same network.
This is the only way to see the 4tb western digital green hard disk.
« Reply #64 on: February 25, 2014, 03:32:26 PM »
Anyone using this  thread should also take this into consideration:-
http://www.mede8erforum.com/index.php/topic,13746.msg89764.html#msg89764
If others say a drive works, and it isn't for you, then the issue is likely to  be your enclosures out-dated sata to usb bridge chip.
Offline fits79
« Reply #65 on: February 25, 2014, 03:34:52 PM »
ALREADY TALLIED THAT MANY MANY MANY TIMES.
So i tallied one LAST TIME.
The western digital 4tb green it doesn't see it at all the med600x3d but the wdtv live gen3 see it normally.
How that would happened?
I DON'T know if it see normally others 4tb hard disk but this western digital green 4tb DOESN'T so.....
« Reply #66 on: February 25, 2014, 03:41:52 PM »
I'll answer in the dedicated thread.
Offline haber
« Reply #67 on: April 16, 2014, 07:49:39 PM »
WD My Book 4TB  USB 3.0 (Model WDBFJK0040HBK-EESN), works fine with MED600X3D.
  • Helpful Contribution Status: +114/-28
« Reply #68 on: May 16, 2014, 10:52:19 AM »
Seagate Backup Fast
http://www.seagate.com/external-hard-drives/portable-hard-drives/performance/backup-plus-fast-hdd/
A sample of the Seagate Backup Plus 4TB was kindly supplied by Seagate for testing compatibility with Mede8er X3D Series.
Mounting time = 75 sec with drive 2/3 full
The drive has been tested and works fine and we can recommend this model for use with Mede8er X3D Series.
EDIT: 20 June 2014 - NOT WORKING IF X2 / X3D has PCIE WiFi installed. - investigating
Personally very impressed with this drive and will probably buy one for my personal use ;D
« Last Edit: June 20, 2014, 04:11:26 AM by Mede8er1 »
Offline neoricky
« Reply #69 on: July 29, 2014, 02:10:33 AM »
I got one of this seagate expansion 4TB external hard drive but right after connected to my med800 without shown and plug in to pc pop up a message said error. I tried to scan it to repair but couldn't succes. What went wrong?
Offline hisokan
« Reply #70 on: October 10, 2014, 12:24:54 PM »
I have exactly the same but for me it doesn't work on my MED600X3D (V 3.0.7). I've tried to convert to GPT, but it didn't works again. How did you manage to make it works?
Edit: I removed my password on the HDD, and it works perfectly now. I can confirm it's compatible with MED600X3D.
« Last Edit: February 24, 2015, 01:21:32 PM by hisokan »
