Author Topic: External USB 3TB /4TB Compatibility with X2/ X3 Series  (Read 98641 times)
Offline spyne
Re: External USB 3TB /4TB Compatibility with X2/ X3 Series
« Reply #15 on: September 02, 2013, 03:37:50 PM »
Works with Toshiba Stor.E Canvio 3.5" Desktop (P/N HDWC130EK3J1), after erasing/converting to GPT/creating 1 NTFS partition using Win8. I had to chkdsk /f the disk to get it recognized (there was a few index errors although I ejected it), v2.00 firmware is very sensitive to NTFS errors. Also, I had to plug the disk before powering on the X3D or it would'nt be recognized either. Next step, being able to access it through Samba!
I confirm.
I got this unit also and after having made a full wipe on it then having recreate the table partition using GPT instead of MBR via Windows 7 plus having formatted it with NTFS, we can access the whole 3TB storage space.
thx
Offline TitleTown
« Reply #16 on: September 13, 2013, 09:16:57 PM »
Hi all-
Brand new to the forum and am considering purchase of MED1000X3Dů.  However, I am confused as to what if any 2TB internal hard drives work.  I read through this thread and still can't figure it out.  Is there a compatibility list somewhere i have overlooked?
Thank you!!
« Reply #17 on: September 14, 2013, 07:24:34 AM »
2TB should be normally general ok - this thread is about 3TB or higher.
Offline TitleTown
« Reply #18 on: September 14, 2013, 11:40:19 AM »
Ok, Thanks.  But, is there a internal HD compatibility list somewhere?  I looked around the forum and couldn't find one.   Certainly, not every 2TB Internal HD will work?
Offline docbill
« Reply #19 on: September 22, 2013, 02:38:05 PM »
Has anyone tried the 4TB red drives in the med1000X3D?  They were on sale last week, so I was tempted to get one.   But in the end the uncertainty if it would work stayed my hand...   Of course what I really want is an 8TB Red drive, but they don't even make those yet.
« Last Edit: September 23, 2013, 01:03:09 PM by docbill »
Offline inikad
« Reply #20 on: September 22, 2013, 03:24:52 PM »
Earlier this year, they were talking about a RED 5TB by end of  2013.  ;D
Offline argumon
« Reply #21 on: October 11, 2013, 07:58:31 AM »
I have a
WD My Book 3TB
WCC1T0664776
FW 1.042
Formatted with NTFS under Windows 8 64-Bit
and is is not found by my 600X3 with latest FW 3.
Should this work?
Update: migrated from mbr to gpt, now it works  :)
« Last Edit: October 11, 2013, 10:14:31 AM by argumon »
Offline jrc3d
« Reply #22 on: October 11, 2013, 09:27:55 PM »
Is Seagate Backup Plus STCA4000300 compatible with 1000x3D (v.3)?
Offline jrc3d
« Reply #23 on: October 16, 2013, 08:22:19 AM »
Nevermind.  I just bought one and I can confirm that this is fully compatible
Offline gabrielydante
« Reply #24 on: November 11, 2013, 07:26:35 AM »
Recently i just bought a Seagate expansion 4tb hdd, and with med8er 600x3d run ok. Only i have a problem, if i connect the drive to pc and boot the pc, the pc is blocked, then i must boot another time and when finish the pc boot dont recognize the drive, then i need to unplug and plug another time the dc adapter and now the pc recognize the drive. if i boot the pc without plug the drive in the usb port and when the pc finish the boot and plug the drive to the pc usb port all is fine. Then, after this problem i have fear that miss 4tb full of movies. i bought this drive for joint several small drives (2tb, 1,5 tb and 750 gb) and after let this drives empty for new movies but now a have fear to lost this information... You recomend me doing this?
« Last Edit: November 11, 2013, 09:07:33 AM by gabrielydante »
« Reply #25 on: November 11, 2013, 09:39:14 AM »
Lot's of PC issues.
1) The PC boot process starts with the motherbaord booting using the motherboard bios. That can have code that  deals with USB drives for boot purposes well before the operating system is loaded. That code may not like that 4 TB drive, it would depend on the age of the PC.  There may be a setting you  can change in the bios to  get around this, such  as turning off Boot from USB.
2) Your USB controllers may  also not like the drive unless it is detected by hot docking.  That is also a problem  for some motherbaords and the player in Slave Mode, which also  has to  be powered up  first before connecting.  This also  depends upon the age of the pc.
« Reply #26 on: November 11, 2013, 10:21:37 AM »
Thanks, the pc is of stone age...(jeje) have more than 10 years, have xp 32, 3 giga ram, ...but usually i have connected to this pc 2 external usb hdd (3,5" wd my book), one of 2tb and one of 750 gb, i have this drives full of movies and access to its from med8er 600 by samba. And i boot the pc with this drives connectec always and have no problem never.
« Reply #27 on: November 11, 2013, 10:28:05 AM »
XP and large disks is a problem (bigger then 2TB)
http://support.microsoft.com/kb/2581408
Also the bios of the pc needs to support it.....
« Reply #28 on: November 11, 2013, 12:09:33 PM »
Thanks, then i understand that the problem is OS. not the hdd. The final use of this hdd when i copy the 4tb of movies in it is having always connected to the med8er 600x3d in the usb port and occasionally plug it to pc for erase movies. Then if the problem is not the hdd i have not problem.
« Reply #29 on: November 21, 2013, 06:50:35 AM »
After many tests and download drive settings software from seagate i had got return the 4tb seagate expansion drive, the reason is that i need to unplug and plug the ac adapter of the drive every time that i turn on the med8er600 for the drive appear on the usb listed ond med. i try using drive settings software for set the power saving to never but no changes. I have four wd mybook essentials (2, 2, 1.5 and 750) and never had problems with pc and med8er. Now i had buy a 3tb wd my book essential external hdd but i see some post before that is possible that i have problems with the gpt or mbr format, i dont understand this, can anybody explain me the way to change from mbr to gpt and if i need to make it? I have a pc with windows xp.
Thanks.
