Author Topic: XBMC  (Read 19779 times)
Offline sajarac
XBMC
« on: April 09, 2013, 12:00:01 PM »
Hi, any guru than can give me a hope!!!!
I really want XBMC installed on Mede8er, specially the AEON function for the music. is really really impossible or in a near future can be installed, otherwise I'm thinking seriosly swithc for the new mini android TV Box, cheap solution...love the mede8er but love the other funcionalities too.  any advise will be very appreciated!!  May respects
Re: XBMC
« Reply #1 on: April 09, 2013, 12:56:20 PM »
That is a Feature Request. The code on the player is not open to modification by the Community.  Personnally, I would buy an Android Tab and wait for the new Net Api's apps to arrive.  Unless you can gurrentee that  V3 or later Android is on a TV box I wouldn't bother with it.
« Last Edit: April 09, 2013, 01:03:11 PM by jer1956 »
Offline dfran1
Re: XBMC
« Reply #2 on: August 11, 2013, 11:10:51 AM »
Hi all,
  I did not want to start a new thread for this question.
1. Do the mede8er players run xbmc or a modified locked down version?
2. Can I install other Add On XBMC Repositories? or is it locked down to this?
Thanks for all replies!!
Sorry if these are newby questions.
Re: XBMC
« Reply #3 on: August 11, 2013, 11:32:14 AM »
This is not an old post...so  the reply given to  the OP is still valid.
Re: XBMC
« Reply #4 on: August 11, 2013, 11:37:14 AM »
No. They have their own player code, no XBMC code.
No. As no XBMC is running...
Offline dfran1
Re: XBMC
« Reply #5 on: August 11, 2013, 01:51:45 PM »
Thanks to both of you!!!
Again I am sorry for the newbie post.
I thought this ran xbmc, as it kind of looks like an old version of xbmc that I ran at one point.  But it is not thanks to both of you.
Thank You!!
Re: XBMC
« Reply #6 on: August 11, 2013, 01:54:35 PM »
It's quite popular to emulate the look of XBMC, but it doesn't mean what's underneath is anything like  it.
