Alternative way to make the mentioned dump:
1) Create a folder with name hdmi_test_dora129.3 on a USB stick (in the root), and plug it into Mede8er
2, Connect the Mede8er to AMP/TV, > (please use HDMI), and set the audio mode of Mede8er to (HDMI passthrough)
3, Now play a movie on the Mede8er and ENTER number '0'
4, Now you will see that the usb stick starts flashing and writing the dump in the dora folder. Wait some minutes before unplugging the usb stick, don't pull it when it is still flashing
If this does not work, then it must be somehow usb stick related.
Then please try an alternate usb stick.
Also be sure that you created exactly the folder name on the stick as mentioned above.
