Author Topic: X3 Nice Xmas Skin by Mike42  (Read 6741 times)
« on: October 06, 2012, 08:18:15 pm »
How to change a skin:
IMPORTANT - Setup ---> MISC ----> Home Page Text  Set to 'Off'
Download X3 Nice Xmas Skin by Mike42
