Author Topic: X3 Blue Room by GlynRS2 Mod by Mede8er1  (Read 6834 times)
« on: October 03, 2012, 09:21:02 am »
How to change a skin:
IMPORTANT - Setup ---> MISC ----> Home Page Text  Set to 'Off'
Download X3 Blue Room by GlynRS2 mod by Mede8er1
Offline eentje
Re: X3 Blue Room by GlynRS2 Mod by Mede8er1
« Reply #1 on: October 03, 2012, 09:27:13 am »
to bad i dont own a x3 it looks damn nice :)
www.thetvdb.com contributor
