TheKillingBean
I think you need to do a EDID test on your system to see what the TV actually supports. Install latest Beta V1.0.3- 21Sept
TEST A 1. Create a folder 'hdmi_test_dora129.3' in Root of a USB stick and plug it into the X3.
2. Power the X3 up and on the Home Page press number key on the Remote Control '1025' and the X3 will read your systems EDID and save it save it into folder 'hdmi_test_dora129.3' on the USB Stick.
3. Zip the contents of the folder and name it 'TEST A' and mail it to
technical@mede8er.com4. Delete the contents of the folder 'hdmi_test_dora129.3
TEST B1. Create a folder 'hdmi_test_dora129.3' in Root of a USB stick and plug it into the X3.
2. Power the X3 up Play a video and pres the '0' button on the Remote control and the X3 will read your systems EDID and save it into folder 'hdmi_test_dora129.3' on the USB Stick.
3. Zip the contents of the folder and name it 'TEST B' and mail it to
technical@mede8er.com.
Pls include your system setup and make and model of Amp and TV
