Author Topic: Problems Setting Up NFS on 1000X3D and Synology  (Read 17010 times)
Offline edcar
Re: Problems Setting Up NFS on 1000X3D and Synology
« Reply #15 on: September 26, 2012, 05:56:55 PM »
Can you give your 1000X3D configuration and your Synology configuration.
Maybe with one or two screenshoot?
Thx
Offline hdmkv
« Reply #16 on: September 26, 2012, 06:21:36 PM »
+1.
edcar, are you getting stuttering via NFS using your 1812+ with DSM 4 versus using SMB for really high bitrate BD rips?
Firmware: Always Latest Beta
Networked via CAT5e
Offline edcar
« Reply #17 on: September 26, 2012, 06:37:04 PM »
HDMKV:
No, but with the another Player, i have not problem
My problem is only with MED1000X3D.
For me it would be simpler if one could parameters NFS in the MED1000X3D  :P
With:
IP synology
Path on the Synology Ex: \
VOLUME1\VIDEO
VOLUME1\Music
VOLUME1\....
« Reply #18 on: September 26, 2012, 07:54:06 PM »
edgar,
your issue is different as hdmkv, as he is now able to connect to his NFS shares but has lower streaming performance then with samba sharing.
in your case you are not able to connect to your nfs shares if I understand correctly.
Did you follow the setup steps as described in the beginning of this post?
- do you have jumbo frames switched on or off on your synology
- did you try to use the latest 1.0.3 21 sept open beta? that has NFS path scanning? that helps to connect to the proper path if you have issues with that
- is your synology nas set on a fixed ip addres?
Offline edcar
« Reply #19 on: September 27, 2012, 02:07:57 PM »
On my MED1000X3D i place one IPFIXED and on my Synology, i fixed the Ip to MED1000X3D and one another with the Host Nname MED1000X3D.
- do you have jumbo frames switched on or off on your synology --> YES   :P
- did you try to use the latest 1.0.3 21 sept open beta? that has NFS path scanning? that helps to connect to the proper path if you have issues with that --> YES  :P
- is your synology nas set on a fixed ip addres? -->YES  :P
I took another 1000X3D in my stock.  :o
And now all functions correctly  ;D
The problem comes from the model of exposure.  :(
I had a bug with this one, but I cut off the supply and to start again the MED1000X3D and all returned correctly.
But now, all is ok.  8) 8)
 :P :P :P
« Last Edit: September 27, 2012, 02:14:28 PM by edcar »
« Reply #20 on: September 27, 2012, 02:25:20 PM »
 :P :P :P
So you saying getting everthing working with a second x3 then allowed the first to work as  it should?
Offline edcar
« Reply #21 on: September 27, 2012, 05:05:09 PM »
As with the second who functioned directly!
