Author Topic: Cant write on internal HDD  (Read 7913 times)
Offline ricardod
Re: Cant write on internal HDD
« Reply #15 on: November 19, 2012, 03:16:34 PM »
Yes, I've already connected a PC to the MED1000X3D using the blue cable and I can see the internal HDD and work with it without issues. So I think then the only option I've at this point is to reformat then. Anyway, just for general knowledge, is it possible to use Samba and NFS at the same time on the MED1000X3D unit...?
Thanks and regards
