Author Topic: Cant connect to my Qnap TS-509  (Read 3976 times)
Offline ah786
« on: September 16, 2012, 10:17:13 AM »
Hi
Im trying to connect to my qnap ts-509 using my Mede8er MED1000X3D, but having problems, i have connected it to my billion router via Ethernet, the samba option is on but it still doest recognise my user name and password, any help would be appreciated here. I have firmware V1.03 30Aug 2012.
Re: Cant connect to my Qnap TS-509
« Reply #1 on: September 16, 2012, 12:30:47 PM »
ah786
Pls use the IP based method as described in the User Manual Page14
The Login Screen Host Name method has a bug
http://www.mede8er.org/artwork/temp/Mede8er_med1000x3D_user_rev1_24Aug2012.pdf
Offline ah786
« Reply #2 on: September 16, 2012, 01:59:00 PM »
Hi
Thanks for your help, i have done that but i still cant access the folder which contains the movies, i have followed the instructions in the manual, and have put in my user name password correctly but it still says login fail, any further assistance would be much appreciated.
Re: Re: Cant connect to my Qnap TS-509
« Reply #3 on: September 16, 2012, 02:19:41 PM »
Two suggestions:
- try to logon with your admin account as this normally has full access always to see if you made some setup sharing privilige error
- check if you have jumbo frames on and turn it off (try mtu size  1500)
Verstuurd van mijn GT-I9300 met Tapatalk
Offline ah786
« Reply #4 on: September 16, 2012, 03:01:58 PM »
Thanks got it work :-)
