Author Topic: Feedback for -- V1.0.3 -- 12Sept 2012 XX OPEN BETA XX for MED1000X3D  (Read 34051 times)
Offline TheKillingBean
Re: Re: Feedback for -- V1.0.3 -- 12Sept 2012 XX OPEN BETA XX for MED1000X3D
« Reply #30 on: September 16, 2012, 07:49:50 PM »
Have you tried turning on autofps?
Verstuurd van mijn GT-I9300 met Tapatalk
Yes I tried autofps on, but the same thing happens. Nobody else have this problem? I think is easy to check. Just watch a movie, press the settings button. Then you can see if the settings is on HDMI Auto or not.
Offline couto
« Reply #31 on: September 16, 2012, 11:31:06 PM »
whats settings you got in your tv ?
what time off file you try to play?
try to reflash the firmware using the power button way (15seconds)
Med1000X3D
Anthem MRX-310
Mitsubishi HC5
LG Oled 1080P
100 inch screen
Router. Linksys E4200
Protocol : UDP 32K
Media Files:ISO 3D, MKV, FLAC
« Reply #32 on: September 17, 2012, 06:46:31 AM »
Can you post some more details about your setup:
1] what brand and type of TV are you using?
2] how is your Mede8er connected? Direct to HDMI/by some splitter/by an audio amp: if yes-which brand and type?
3] streaming from internal disk and or network?
4] if network, streaming over samba filesharing/NFS or Upnp?
« Reply #33 on: September 17, 2012, 08:42:07 AM »
LG 42SL8500
Mede8er trough my Onkyo 609, but also happens if connected to the TV directly.
Streaming from internal disk (SEAGATE BARRACUDA 2 TB 7200 RPM 64 MB 3,5 INCH)
Offline hdmkv
« Reply #34 on: September 17, 2012, 11:57:13 AM »
Experiencing my first stutter with the 1000X3D. It's with the new 'Titanic' 3D BD over wired SMB. Starts around chapter 5, with video stuttering, followed by audio dropouts, and even playback itself freezing. Seems like a network issue. I haven't tried the title via direct USB connection yet. I also played the latest 'Transformers' 3D ISO for about 30 minutes via SMB without issues. Can someone with 'Titanic' 3D do a playback test over network? Thanks.
Firmware: Always Latest Beta
Networked via CAT5e
« Reply #35 on: September 17, 2012, 12:44:19 PM »
hdmkv
Are you using Samba or NFS? As we know NFS bandwidth on X3 is over 25% better than Samba but you need to confirm that your Synology NFS is set to the correct block size. --  ie rsize / wsize should be set to 32768 Bytes otherwise performance will be no better than Samba
Offline hdmkv
« Reply #36 on: September 17, 2012, 02:40:58 PM »
Samba. Had tried to get NFS working a while back, but was unsuccessful. Will retry NFS, but if not, will re-test 'Titanic' 3D via an attached USB.
« Last Edit: September 17, 2012, 02:59:41 PM by hdmkv »
Networked via CAT5e
Offline hdmkv
« Reply #37 on: September 17, 2012, 03:37:32 PM »
Not sure who (Maasbommel or Mede8er1 I think) recently posted instructions on setting up NFS with Synology for 1000X3D. Did a search and couldn't find it. Would you kindly post a link to it? Thanks.
Networked via CAT5e
« Reply #38 on: September 17, 2012, 04:28:55 PM »
hdmkv
I found this but its a different model to yours - maybe worth a read anyway
http://www.mede8erforum.com/index.php/topic,1574.0.html
Offline hdmkv
« Reply #39 on: September 17, 2012, 04:29:56 PM »
Thanks, will try it.
Networked via CAT5e
Re: Re: Re: Feedback for -- V1.0.3 -- 12Sept 2012 XX OPEN BETA XX for MED1000X3D
« Reply #40 on: September 17, 2012, 06:27:41 PM »
hdmkv
Exactlly the same for the 1000x3d.
Also verify if your synology is not on jumbo frames for first setup of nfs.
And try first to connect using your synology admin account  - later when it works you can fall back to separate user accounts. First try setting up simple like this.
« Reply #41 on: September 18, 2012, 10:56:59 AM »
Locked - New Release
Mede9er1
