Author Topic: Remote acess through the (local) Internet  (Read 2882 times)
Offline Fcpiek
« on: September 04, 2012, 07:28:44 PM »
A few hours ago I installed the X3. Setting up was easy and quick.
Currently I was/am using a Conceptronic media player. The X3 is in a transition setup conected to the front AUX HDMI con. of my Onkyo 5009. Update through the USB stick went fine.
Can I use the Internet to update from now on?
DLNA works great on my Galaxy SIII using Skifta.
Remote access however does not seem to get a connection using my SIII. Using a (wired) PC I got a connection but the screen was kind of dead. I could only cycle the lower options, but never got any respons from the X3 itself. A setup mistake or a bug?
What I would like to see is an Android app!
Anyway so far extremely happy with it but still lots of set up of libraries and testing to do.
Fred
Re: Remote acess through the (local) Internet
« Reply #1 on: September 05, 2012, 08:30:28 AM »
Check out Community Tools...there alreadt is android app for the remote interface.
