Author Topic: Feedback for -- V1.0.3 -- 30August 2012 XX OPEN BETA XX for MED1000X3D  (Read 23722 times)
Pls post your feedback here
Offline Domser
Re: Feedback for -- V1.0.3 -- 30August 2012 XX OPEN BETA XX for MED1000X3D
« Reply #1 on: September 01, 2012, 09:55:55 AM »
This is the first firmware release I installed, so no idea if this problem is directly connected to this release.
The X3D is connected directly to my Fritzbox router via LAN. Connection to my NAS no problem.
But, I cannot connect to the Internet, tried DHCP auto and manual - no change.
Entered 8.8.8.8 in DNS, no change, also restarting router did not help. I even put the OpenDNS values in - no change.
Also, I cannot connect to my Synology NAS via NFS (which is my preferred option), via SMB no problem.
« Last Edit: September 01, 2012, 11:29:39 AM by Domser »
LG Cinema3D 55LW4500 / Sanyo PLV Z5
Mede8er MED1000X3D (FW 1.03 - 29.08.)
« Reply #2 on: September 01, 2012, 01:50:37 PM »
Try putting the Gateway ip value into the Manual DNS (server) field.
Offline Domser
« Reply #3 on: September 01, 2012, 02:42:41 PM »
Thanks, I had also done that. Did not work. :-(
« Reply #4 on: September 01, 2012, 03:21:07 PM »
Does the fact you can post mean you have a pc with internet access using the   fritzbox? What does the lan connection for your pc    have for ipv4 data, especially gateway and dns server?
Offline Domser
« Reply #5 on: September 01, 2012, 03:43:10 PM »
Yes I have Internet access, if I plug the Lan cable into another player, it also immediately has access to the Internet. Usually with a LAN cable and dhcp auto on, there is not much that can go wrong.
Gateway IP 192.168.178.1
DNS (on my pc) 192.168.178.1
I have Squeezeboxes and other players connected to the fritzbox, all work fine.
« Last Edit: September 01, 2012, 04:35:22 PM by Domser »
Offline Domser
« Reply #6 on: September 02, 2012, 01:53:28 PM »
NFS works perfectly. I finally found out how to set it up... ;D
But stioll no internet on my X3D
« Reply #7 on: September 02, 2012, 01:59:30 PM »
Is that just the browser based apps (bing xl etc), or is it also  internet radio?
Offline Domser
« Reply #8 on: September 02, 2012, 02:01:39 PM »
Also radio does not work. So nothing internet related works.
Offline pinzzi
« Reply #9 on: September 05, 2012, 03:13:15 AM »
got restart when selecting movie in browser.every first time i turn on media player and select movie browser and that happens.restart happen when i got in page 3 scroll down page.so i turn off the power button and turn on again.and the same happen again when selecting movie.
i use 1tb wd my pasport and 3tb wd my book essential.
in setup i use 1080p auto
24hz 1080p on
auto frame off
can u fix this problem sir?
thanks in advance
« Reply #10 on: September 05, 2012, 08:35:43 AM »
Those usb drives may have hidden security partitions. Meds only work with standard usb drives.
Offline pinzzi
« Reply #11 on: September 05, 2012, 10:19:20 AM »
should i create new partition and format my eksternal hard drive?is this will resolved my problem?
i use wd 1tb my passport and 3tb my book.
they got formated from the factory and ntfs
« Reply #12 on: September 05, 2012, 11:00:13 AM »
I would suggest to first verify with windows diskmanager if those disks contain multiple partitions.
Offline pinzzi
« Reply #13 on: September 06, 2012, 10:38:25 AM »
there is no multiple partitions when i check in diskmanager.
is this hardware defect or just firmware error?
that is so strange when i see browse movie and i go down several page then its restart it self.its happen over and over again
Offline Domser
« Reply #14 on: September 06, 2012, 08:14:05 PM »
Hello,
the same problem at my med1000. I cant get an internet connection by wlan. The connection  tested as ok, but I cant open youtube, internet or something like that.
Thanks, I am glad you have the same problem. I thought I was alone.
