Author Topic: Just Got the MED1000x3d in USA overview  (Read 27244 times)
Re: Just Got the MED1000x3d in USA overview
« Reply #45 on: August 30, 2012, 06:34:11 PM »
Jumbo frames (>1500) is in most case not really working for streaming players.
Data comes faster then the unit can play and buffer and if there is no RX/TX flow control it will overflow the buffer and finally you see hickups.
Offline couto
« Reply #46 on: August 30, 2012, 10:12:32 PM »
I have jumbo frames turn off by default, but still the MTU value is 1500, but if i choose 2000, 3000, 4000 etc the jumbo frames are activated...
synology dsm 4.0
Med1000X3D
Anthem MRX-310
Mitsubishi HC5
LG Oled 1080P
100 inch screen
Router. Linksys E4200
Protocol : UDP 32K
Media Files:ISO 3D, MKV, FLAC
« Reply #47 on: August 30, 2012, 10:45:17 PM »
I also have a Synology as one of 2 NAS boxes.
You need to turn Jumbo frame option off and that will give mtu 1500 (which is ok).
Setup of NFS is pretty easy.
Set NFS service on in Synology config.
Then select a share you want to make avail using NFS.
e.g. video
Then goto config panel, shared folder.
Select the folder you want to share over NFS.
Press on NFS priviliges on top.
Press create
Fill in your Mede8er ip number
Privilige read/write
Root squash no mapping
Enable asynchronous
You will see the file path on the bottom of this window. You need to use this name later on your mede8er.
On your mede8er:
Goto Network - NFS
Press Menu button, select Add
now fill in the ip number of your NAS
fill in the path (as mentioned above). e.g. /volume1/video
Thats it. You should now be able to enter on the saved NFS path.
