Author Topic: NAS Drive compatibility  (Read 4526 times)
Offline wink
« on: August 20, 2012, 12:12:32 PM »
Hi, I'm very keen on getting a 1000X3D when they are eventually released in the UK and i'm currently in the process of getting my home all networked. I'm looking to get a NAS drive to store all the music, movies etc and was considering this one.
http://www.ebuyer.com/290542-netgear-rnd4000-readynas-nv-v2-4-bay-no-disks-nas-enclosure-rnd4000-200eus
has anyone had any experience in using it?, it does have gigabyte networking and is SMB compatible so i don't think it should have any issues transferring 3D Blu-ray files over the network, should it?
Offline demonrecords
Re: NAS Drive compatibility
« Reply #1 on: August 21, 2012, 12:36:08 PM »
Should work just fine.
Why do you keep on watching the porno after you came?
Offline eentje
« Reply #2 on: August 21, 2012, 02:12:37 PM »
personally i would advice getting a synology nas :) best nasses around atm :)
www.thetvdb.com contributor
« Reply #3 on: August 21, 2012, 07:01:18 PM »
I use Qnap, great too, although a bit more expensive.
Offline Hsd
« Reply #4 on: August 21, 2012, 08:25:00 PM »
In my experience the Netgear stuff is just not it. It is way to underpowered for media streaming. Go for Synology or QNap.
« Reply #5 on: August 21, 2012, 09:06:18 PM »
My vote is for Synology - great FW features and very good FW support.
