How to change a skin:
To load a skin -- just download it and unzip /unrar it to a folder. In X3 navigate to this folder and press the ‘Menu’ button and select ‘Set to Skin Option’ The new Skin will be loaded into flash memory and used as the new default. Switch 'off' the 'Home Page Text' under Misc in the Setup Menu. You can revert back to the original default skin at any time by selecting the option ‘Restore Default Skin’
The Thumbnail Focus Images can be replaced with these colored Focus images in any Skin Pack
Download Bold Colour Thumbnail Focus Skin Set
