Author Topic: getting random quits during .MKV-- 15August 2012 XX OPEN BETA XX for MED1000X3D  (Read 12091 times)
Offline dekka007
Seem to be getting random quits during .MKV playback across the network.
Screen will go blank for 5-7 seconds without warning / stuttering or freezing - then the main screen comes back with Media Library highlighted.
Occurring on several files.
Not sure if it's a network problem (I would assume freezing buffering or stuttering if thats the case) or firmware issue.
Files are located on SMB share on gigabit wired ethernet.
« Last Edit: August 17, 2012, 09:54:13 AM by Maasbommel »
dekka007
As already explained vie email
This is a typical symptom of having 2 x mede8ers on the same network with the same Host Name. Pls check this
Can you please post more details of how you upgraded, and your setup, in the X3 Networking Issues section. This section  can become untidy if we start fixing possible setup issues in the Firmware Response thread.
Update: have split off this topic for isolated troubleshooting.
We expect some config setup issue at the moment, not specific FW issue.
Hi dekka007,
Were you already able to solve your issue?
Offline dekka007
It does not seem to be happening as frequently as other day.    Occasionally every 3 or 4 movies watched.
My other X3D has SMB switched off.
I am assuming network issues however it is wired with Giga ethernet.    Possibly MAC OSX implementation of SMB that is the issue.
Offline Mike42
@dekka007:
Had the same issue with my X2. had to configure my ethernet card to half duplex i.s.o. full duplex.
after that no more trouble's with quiting movie's
« Last Edit: August 22, 2012, 04:55:33 PM by Mike42 »
Mede8er : MED1000X3D
Network: Wired CAT5
AV receiver: Onkyo TX-NR414
additional equipment:
Offline dekka007
Mike42,
Thanks will give that a go tonight.
Any feedback from the Mede8er team as to why this occurs and why half duplex would solve it?
It can be some Gbit incompatibility issue between the Mede8er and your network.
If that happens setting RX/TX flow control on or setting to half duplex modes is one of the tricks around it.
Any feedback Dekka?
Did the subscribed change in settings help?
Offline dekka007
Didn't fix it for me.  However I changed it to Jumbo packets MTU 9000 seems to have solved it.
Still having issues streaming Blu ray rips of 31gb and 53gb files via gigabit ethernet from imac.   Just stutters a lot on those sort of huge MKV files.
I am not sure if the problem is the iMac and the firewire 800 drive that the file is located on......
They play fine from the HD on the X3D.
Tried jumbo frames Off? Mtu 1500?
Offline dekka007
Makes no difference to me.
Installed a new NAS synology DS1512+ connected it to the same switch as Mede8er via CAT 6 cables and gigabit switch.
Avatar 3D ISO fails to stream smoothly with either 5.1 or DTS selected.   It streams but stutters when large movement on screen and sound drops off.
Also Avengers 30GB 2D MKV same problem.
No idea the problem.  However if I put on internal HD in the Mede8er they play ok.
Running the latest 31st August firmware.  Makes no difference if SMB or NFS.
1.  New CAT 6 Cables
2. New Gigabit Switch
3. New Gigabit NAS (was streaming from imac prior with same problem(
No idea what else to try...
Can you do some comparison tests with a PC? You can then monitor the throughput using monitoring tools.
Is your nas and your Mede8er connected to the same switch?
Or is there some other setup with multiple switches and routers?
Please try to describe a bit more details how things are connected and what components are used in your network as detailed as possible to get some idea what could be the root cause.
Best way to troubleshoot these kind of issues is to start with a simple as possible network setup and if that is working ok, move to more complex structure and compare again.
