and how does the Emergency Recovery Procedure work?
The machine doesnt react at all. When i start with the power button, the big 8 appears in the screen and than nothing happens.. can t power off. only by pulling of the poweradaptor.
Try flashing the same firmware you downloaded (using the Emergency Recovery Procedure). If that fails, try downloading the version you had before and do the Emergency Recovery Procedure again...
