Pages: [1] 2   Go Down
Author Topic: Mede8er 500X2, Pioneer VSX 520K And Optoma HD20 Problem  (Read 967 times)
veez
« on: June 26, 2012, 09:29:58 pm »
Hi Guys
Was wondering if anyone can help me out
My current setup is a MED500X hooked up to a Pioneer VSX 520K amp using the AMPS HDMI switch feature and then out to a Optoma HD20 Projector
I wanted an upgrade so i bought a 500X2
i simply replaced the 500X with the 500X2 and then all the problems started
The unit starts up fine but the projector keeps dropping the video signal every couple of seconds
I managed to drop the resolution to 480p and that works fine
I then plugged it into the Room tv and did a firmware update to v2.0.7 (it already had this version on so i did it again anyway)
In the room i'm able to view everything fine on 1080p 60hz
Why does my 500X work fine with my setup but the 500X2 doesn't ?
Should i just return the 500X2 and get something else maybe ?
Please help
« Reply #1 on: June 26, 2012, 09:54:23 pm »
Do you see the same issue if you connect your X2 directly to your Projector in stead of going by the amp?
Just to get an idea if it could be some setting on your amp?
veez
« Reply #2 on: June 26, 2012, 09:59:37 pm »
Hi Maasbommel
To be honest, i haven't tried that
I was so disappointed that it didn't work, i just tried the basic stuff and then packed it away again
I will give this a go and see
veez
« Reply #3 on: June 26, 2012, 10:21:32 pm »
K, did some testing
The cable going to the projector is pretty long, about 20 meters
It does the same thing even if i plug straight into the projector via the same cable
I plugged in my 500X again and that still works 100%
Is there a difference between the HDMI on a 500X and a 500X2 ?
« Reply #4 on: June 27, 2012, 10:50:39 am »
Yes..a huge dpendence upon HDCP and CEA-EDID data from the display. If you search  you will see this problem crops up with projectors..as their HDCP is nortorioulsy unrelaible.   Without HDCP handshaking you can get unexpected resolution chages to SD, or blank  screens.
« Reply #5 on: June 27, 2012, 11:15:16 am »
I suggest you go to the optoma forum and search for HDCP handshaking issues. There may be a firmware upgrade for the projector to improve things.
veez
« Reply #6 on: June 27, 2012, 11:56:04 am »
Thanks jer1956
I will go and take a look
Is that specific to the 500X2 as my 500X works 100 % with the exact same setup ?
« Reply #7 on: June 27, 2012, 12:45:58 pm »
I think someone with an X1 had this problem. It's all "tolerence" when things are unrealiable, as opposed to inoperative. So a differnet chip in the X2 could be enough to change the tolerence limits..and  trigger the problem.
veez
« Reply #8 on: June 27, 2012, 12:59:17 pm »
I did some research and HDCP Handshake issues appear to be pretty common
I can't seem to find any way of updating the firmware on the Projector
Do you know of a decent HDMI repeater that i can try ?
« Reply #9 on: June 27, 2012, 01:45:10 pm »
The problem with this type of problem is that you need to try things before you buy..becuase they might not work.  It'a niche problem..so you pay more. The cost of a solution might as much as the Med itself.
http://www.gspr.com/transformative/te-hds12.html
veez
« Reply #10 on: June 27, 2012, 01:54:47 pm »
I know what you mean
Maybe i should just return the 500X2 and stick with the 500X  Cry
I so wanted an upgrade, the 500X2 would be a waste in the room if i kept it
Thanks for the help
« Reply #11 on: June 27, 2012, 02:04:41 pm »
Here is another solution:-
http://www.digitalconnection.com/Products/Cables/hdm.asp
veez
« Reply #12 on: June 27, 2012, 02:06:58 pm »
The one i need is $499 lol
That is just crazy
What about Cat5/6 extenders
You think those will be okay
I see ebay has them for cheap
« Reply #13 on: June 27, 2012, 02:08:26 pm »
something like this:-
http://www.gefen.com/kvm/dproduct.jsp?prod_id=9420
If you where building a home theater, the cost of these kinds of solutions is relatively cheap.  If your not speding thousands..they are expensive. They fix a known problem..lost of quality with long HDMI cables.
veez
« Reply #14 on: June 27, 2012, 02:12:20 pm »
Yip, something very similar to that
Something like the below
http://www.ebay.com/itm/HDMI-Extender-by-Cat5e-6-Cable-Full-HD-1080p-up-to-30-M-NEW-/110819188801?pt=US_Video_Cables_Adapters&hash=item19cd56a041
Do you think it will work better ?
I currently have 2 x 10m HDMI cables with the below joiner/repeater
http://www.ebay.com/itm/130FT-40M-1080p-1-65G-bps-Mini-HDMI-Repeater-Extender-Amplifier-Booster-HDCP-/180875324113?pt=US_Video_Cables_Adapters&hash=item2a1d026ad1
Pages: [1] 2   Go Up
