Pages: 1 2 3 [4]   Go Down
Author Topic: Can't use the name WORKGROUP  (Read 2550 times)
Sten1972
« Reply #45 on: June 11, 2012, 12:04:13 pm »
IPV4 Gateway = xxx.xxx.x.x
IPV4 DNS Server = xxx.xx.xxx.xx
« Last Edit: June 15, 2012, 11:47:31 am by Sten1972 » Logged
« Reply #46 on: June 11, 2012, 12:06:29 pm »
That second is not a local IP..it's the address of the DNS server your ISP hosts.  So you don't have a DNS proxy in your router.
You can try using your PC to host a proxy:-
Just read the bit about Acrylic. Acrylic is normally used to speed up browsing.
You don't need to modify the DNS or WINS files.
« Last Edit: June 11, 2012, 12:12:39 pm by jer1956 » Logged
Sten1972
« Reply #47 on: June 11, 2012, 12:12:02 pm »
Ok. I will buy a new modem with a built in router then. And you say ALL of them has DNS proxy?
« Last Edit: June 12, 2012, 10:03:00 am by Sten1972 » Logged
« Reply #48 on: June 11, 2012, 12:16:16 pm »
We have not had thsi issue with combined modem/routers..but we can't guarentee there is not one out there which dosn't have one. I would use the tp-link forum to clarify if the model  you  fancy does indeed have one.   If confirmed..you should also  speficy you must have the feature when you buy it..so that if you've been given bad information, and it dosn't,  you can take it back.
Sten1972
« Reply #49 on: June 11, 2012, 12:19:34 pm »
Thanks.
 Smiley
Another question. Does it matter if I connect the 450X2 with a straight or twisted network cable? I'm using a twisted one that worked fine with my Xbox and LG Blu-Ray.
« Last Edit: June 12, 2012, 10:02:44 am by Sten1972 » Logged
« Reply #50 on: June 13, 2012, 03:32:03 pm »
Here is how to see everything on your network:-
http://www.ehow.com/how_8592941_other-workgroups-network.html
Workgroup is an aid to efficiency by filtering what users on  bussiness networks can see. It is not about security..once found..if open to guest users..any device can be accessed.
Sten1972
« Reply #51 on: June 13, 2012, 04:16:41 pm »
Well since my neighbour [CENSORED] at computers I changed his Workgroup name instead of mine.
 Grin
FYI. Everything seems to work just fine now even though I don't have DNS Proxy. It turned out that my router was broken (it shut down itself every 5-10 minutes and restarted).  I changed to a new one of same model  and the same firmware.
I've also changed the name for the workgroup and that also works perfect. The 450X2 finds and plays everything.
Smiley
« Last Edit: June 15, 2012, 11:49:43 am by Sten1972 » Logged
Pages: 1 2 3 [4]   Go Up
