Author Topic: "Watched for Mede8er" Windows context menu-item.  (Read 16579 times)
Offline Nu7s
« on: June 03, 2012, 11:01:07 pm »
This file will add a "Watched for Mede8er" menu-item in the context menu that will create a new file with .t extension just like the Mede8er. This way, movies watched on PC can also be marked as "watched" on the Mede8er.
Download
http://www.handsdown.be/i/WatchedForMede8er.rar
Installating:
To install, doubleclick "InstallWatchedForMede8er.reg".
Usage:
To use, right-click on a file and select the "Watched for Mede8er" menu-item. A new file with the .t filetype will be created just like the Mede8er.
Un-installing:
To uninstall, doubleclick "UninstallWatchedForMede8er.reg".
Enjoy!
« Last Edit: January 01, 2013, 07:37:46 pm by Nu7s »
Re: "Watched for Mede8er" Windows context menu-item.
« Reply #1 on: June 04, 2012, 10:44:48 pm »
Thanks for making this tool available for the Mede8er community.
Just gave it its "own" board section under the community tool section.
« Last Edit: June 04, 2012, 10:50:02 pm by Maasbommel »
Offline Skylinc
« Reply #2 on: June 05, 2012, 02:28:35 am »
Pretty slick! Nicely done :)
Audio: HDMI > LG 42LW4500
Offline cornedp
  • X2 Skin Designer
« Reply #3 on: July 25, 2012, 12:18:02 pm »
Tx this is a great share
Offline Nu7s
« Reply #4 on: July 25, 2012, 12:49:09 pm »
I'm happy you find it usefull  ;D
« Reply #5 on: July 25, 2012, 02:23:54 pm »
The download link seems to be down. Attachement is as alternative still avail.
Offline Nu7s
« Reply #6 on: November 12, 2012, 10:42:10 am »
I re-uploaded the file to a file host.
I moved hosts and forgot to re-upload the file on the new host.
Enjoy!
Offline waltersenekal
    • My Personal site
« Reply #7 on: December 09, 2012, 04:12:53 pm »
Hi Thanks this works very nice
I want to do the same for creating NFO files on my PC
if the filename is movie.mkv then I want to create a file movie.nfo
on some forums they say you must replace the %1 with %~n1 but then it does not create the file at all
can anybody help me with this?
Walter
Offline Nu7s
« Reply #8 on: December 10, 2012, 02:06:19 pm »
Walter
You need to change:
@="cmd.exe /c echo \"%1\" > \"%1.t\""
to:
@="cmd.exe /c echo \"%1\" > \"%1.nfo\""
(%1 represents the current folder/file name)
But why would you wan to create a blank .nfo file? There are alot of good programs that grab the movie/tvshow's info from various sources and create and fill the nfo file.
    • My Personal site
« Reply #9 on: December 25, 2012, 04:10:36 pm »
Hi
I have found that Y2M does not get all my shows correctly
So I create the nfo file with the imdb link in and then I know that it will fetch the correct movie info for me.
If i have movie named "movie.mkv" and I use the command you recommended then I get "movie.mkv.nfo"
i need it to be "movie.nfo"
@="cmd.exe /c echo \"%1\" > \"%~n1.nfo\"" on the internet there is an article that say %~n1.nfo extract only filename without extension bur it does not work from the registry?
Walter
Offline Nu7s
« Reply #10 on: December 26, 2012, 11:23:08 pm »
I'm working on a simular sollution to add a <watched> tag in the .nfo file for XBMC. I had to call a separate bach file to do this.
For the registry I use:
@="c:\\Watched\\WatchedEpisode.bat \"%1\""
And in the .bat file:
echo. ^<watched^>true^<^/watched^> >> "%~n1.nfo"
It's not easy, but If you continue you will find a solution.
But, if I may recommend some other software to scan your movies:
http://thumbgen.org/
http://mediacompanion.codeplex.com/
They both need some tweaking of the settings, but Thumbgen works wonders with the mede8er.
Good luck.
Offline zout
« Reply #11 on: December 30, 2012, 11:27:37 am »
Seems like a great tool, but unfortunately the file is not available anymore at http://www.smallfiles.org/download/3569/WatchedForMede8er.rar.html .
zout
« Reply #12 on: December 30, 2012, 04:38:38 pm »
It is also attached to the first post of this thread....
http://www.mede8erforum.com/index.php/topic,8589.msg54581.html#msg54581
Offline zout
« Reply #13 on: December 30, 2012, 05:22:19 pm »
Thanks, my bad. I wasn't logged in when I checked for an attachment  :-[
Offline Nu7s
« Reply #14 on: January 01, 2013, 07:35:14 pm »
I re-uploaded to my own hosting and update the post above. To download:
