Author Topic: Mac users, X2 series' Jukebox and DuneX: the solution is here!  (Read 140674 times)
Offline mognons
  • printf("Hello, world! \n");
Re: Mac users, X2 series' Jukebox and DuneX: the solution is here!
« Reply #135 on: November 08, 2014, 11:00:22 AM »
Hi Clint65,
as you may know, DuneX2Medeber is no longer developed nor supported due to the inclusion of a scraper in newest Mede8er firmware, setting the uselfulness of an external scraping system (for Macs) next to zero.
However, I took a brief look at DuneX 0.9.2_m, loading it with a bunch of movies, exporting the library and firing up D2X v. 1.6.1 (latest available): it all worked without flaws, displaying the movies which were successfully scraped in DuneX...
Hello !
I've just downloaded DuneX 0.9.2_m and the latest version of DuneX2Mede8er
DuneX works fine, it's configured to export for med500, jpg. It generates the dune xml file.
But when I try to open this db with DuneX2Mede8er, I just see a folder structure, without any movie files in it.
I tried with duneX 0.8.xx, it doesn't scrap anything (no information found), but when the db is exported it works fine in DuneX2Mede8er.
I'm kind of stuck here. Is this a compatibility issue between DuneX 0.9.2m and DuneX2Mede8er ?
Thanks in advance !
Proud user of DuneX2Mede8er
Offline Clint65
« Reply #136 on: November 08, 2014, 11:53:07 AM »
Thanks a lot for your answer.
I must do something wrong somewhere, I'll try again.
I still want to use it to bulk fix my library, d2x is the fastest way, it's not so useless !
Clint
Offline gazzario1971
« Reply #137 on: December 27, 2014, 06:38:53 PM »
I'm the proud owner of a new MED600X3D which I got for Christmas; I've been trying to set up an NFS, but I'm a bit of a newbie to all this, so any help would be greatly appreciated. I'm running my files from a MacBook Pro 13" running Yosemite with a HDD connected (this is where my movie and TV series files are located); I downloaded the latest DuneX as I saw from this very forum that it could do the job in terms of scraping movie info and poster images - however, whilst it's performing as expected for my TV series, it's pulling down no information for my films whatsoever! Even if some of them are not perhaps named as they should be, certainly most of them are, but no joy... Any ideas or anyone with a similar issue?
Thanks,
Gareth
« Last Edit: December 27, 2014, 08:43:51 PM by gazzario1971 »
« Reply #138 on: December 28, 2014, 08:23:53 PM »
I've since gone through my library in an attempt to rectify this and renamed nearly all of my films and popped them in their own folder; movie info is now getting pulled down, but no image or movie posters. I'm obviously doing something wrong, but I've no idea what. Any help greatly appreciated.  ???
Re:
« Reply #139 on: December 28, 2014, 10:15:21 PM »
If you put the focus on an cover and press menu and then choose edit.  Can you scrape then and do a save?
If not then check if you enabled nfs write on your shares.
It sounds like you only have read enabled and not write.
Offline jose111
« Reply #140 on: May 07, 2016, 07:04:59 PM »
Modified version of DuneX  0.9.2 with right gui now.
Works on Yosemite:
https://www.dropbox.com/s/4ght1v0p7n7nzv8/0.9.2_modified.zip?dl=0
i cant download it, can anyone share it, please?
Im on mac yosemite now, i leave win7 with yadis, what is the best options for scrapper? DuneX?
 thx!
Offline macuser
Optoma HD80,Sharp LC-52DH65E, Mede8er MED1000X3D 3 TB WD green HDD -> with ethernet cat 6 to Time Capsule 3 TB, Marantz NR 1602,Apple TV2,Dune HD Duo, LG HR550, Pace DS-831,Roister HT-3300
Sharp LC-42SB55E,  Mede8er MED400X2,Yamaha YSP 800,Samsung BD C5900,Dune Lite 53D,Apple TV3
MacBook Pro, MacBook & MacPro, latest Lion OS
WD MyBookWorld II 2TB NAS Server
Offline jose111
« Reply #142 on: May 09, 2016, 09:09:27 AM »
Here is: http://depfile.com/2HVAX15PQcc
thank you very much!
This afternoon i will try!  ;)
Offline Heinzy
« Reply #143 on: December 29, 2016, 07:52:20 AM »
@macuser
Doesn't scrape anything for me, but thanks anyway.
Offline giangi70
« Reply #144 on: March 04, 2017, 04:36:15 PM »
ciao Mognons,
ti scrivo in italiano perchè cosi mi spiego meglio .
Ho appena acquistato un Meder800x3d e sto cercado di capire come inserire le locandine sui film.
Utilizzo: MacBookPro con 10.11.1 - DUNEX 0.9.2 - DuneXtoMede8er 1.6.1.
Ho collegato il Meder800 al mac ed importato in dunex i film da li sono riuscito a inserire le locandine con le info. Dopo di che ho esporato la libreria in modo da poterla acquisire con Dunextomed8er.
E qui sorge il problema in quanto quanto apro la libreria il programma mi puo aprire solo il file dunex.xml ma non mi importa niente altro...
sicuramente ho sbagliato qualche passaggio ma nei forum in rete avevo trovato questo procedimento.
ti sarei grato se mi dassi qualche suggerimento su come fare
ciao
Gianluca
Offline hazepau
« Reply #145 on: July 20, 2018, 10:18:17 AM »
Is this still working on a mac in combination with a MED500X? Is want to get rid of YAMJ.
Offline hazepau
« Reply #146 on: July 25, 2018, 04:11:40 PM »
Anyone???
