Author Topic: Using Skin Pack and Custom Genre Icons Together?  (Read 12517 times)
Offline hdmkv
« on: May 21, 2012, 02:26:13 PM »
Hope someone can help. I installed Between_the_Planets_skin, which is very nice. Then, I followed instructions and installed one of GlynRS2's custom genre icons. Problem is this causes parts of the Mede8er UI to revert to the default skin (namely the main UI icons for Favorites, Media Library, Movies, etc.). Is there a way I can have both? I want to have everything from Between_the_Planets_skin, but also GlynRS2's custom genre icons for my network share folders inside 'Favorites'. Thanks.
Firmware: Always Latest Beta
Networked via CAT5e
Re: Using Skin Pack and Custom Genre Icons Together?
« Reply #1 on: May 21, 2012, 03:18:32 PM »
Put the genre folder into the skin folder..and skin the now shared parent folder.
Offline hdmkv
« Reply #2 on: May 21, 2012, 03:22:03 PM »
Simple enough... thank you :).
Networked via CAT5e
Offline nemofish32
« Reply #3 on: June 03, 2014, 11:30:59 AM »
Ask you to post this one anymore. To be useful to us.
