Hi
I'm just wondering why this file does not play. It says "Unsupported video"
PS. 3D movies play just fine, so that is not the problem...
General
Unique ID : 244172446863662416809532455183550030049 (0xB7B1E7176807E109B898E854C754A0E1)
Complete name : S:\@New\Thor.3D.2011.1080p.BluRay.Full-SBS.x264-TruHD.mkv
Format : Matroska
Format version : Version 2
File size : 16.3 GiB
Duration : 1h 54mn
Overall bit rate : 20.3 Mbps
Encoded date : UTC 2011-12-30 18:52:13
Writing application : mkvmerge v4.0.0 ('The Stars were mine') gebaut am Jun 6 2010 16:18:42
Writing library : libebml v1.0.0 + libmatroska v1.0.0
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 54mn
Bit rate : 18.2 Mbps
Width : 3 840 pixels
Height : 816 pixels
Display aspect ratio : 4.706
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.242
Stream size : 14.2 GiB (87%)
Writing library : x264 core 116 r2074 2641b9e
Encoding settings : cabac=1 / ref=2 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=4 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=0 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=18200 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=40000 / vbv_bufsize=30000 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
Language : English
Default : No
Forced : No
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 1h 54mn
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 526 MiB (3%)
Language : German
Default : Yes
Forced : No
Audio #2
Format : DTS
Format/Info : Digital Theater Systems
Format profile : ES
Codec ID : A_DTS
Duration : 1h 54mn
Bit rate : 1 510 Kbps
Bit depth : 24 bits
Delay relative to video : 11ms
Stream size : 1.21 GiB (7%)
Language : English
Default : No
Forced : No
Text #1
Format : VobSub
Muxing mode : zlib
Codec ID : S_VOBSUB
Codec ID/Info : The same subtitle format used on DVDs
Language : English
Default : No
Forced : No
Text #2
Format : VobSub
Muxing mode : zlib
Codec ID : S_VOBSUB
Language : Swedish
Default : No
Forced : No
Text #3
Format : VobSub
Muxing mode : zlib
Codec ID : S_VOBSUB
Language : French
Default : No
Forced : No
Text #4
Format : VobSub
Muxing mode : zlib
Codec ID : S_VOBSUB
Language : Finnish
Default : No
Forced : No
