Author Topic: Unsupported Video  (Read 472 times)
Skylinc
B8a Tester - 1000X3D
« on: May 12, 2012, 09:56:51 am »
Hi
I'm just wondering why this file does not play. It says "Unsupported video" Sad
PS. 3D movies play just fine, so that is not the problem...
General
Unique ID                                : 244172446863662416809532455183550030049 (0xB7B1E7176807E109B898E854C754A0E1)
Complete name                            : S:\@New\Thor.3D.2011.1080p.BluRay.Full-SBS.x264-TruHD.mkv
Format                                   : Matroska
Format version                           : Version 2
File size                                : 16.3 GiB
Duration                                 : 1h 54mn
Overall bit rate                         : 20.3 Mbps
Encoded date                             : UTC 2011-12-30 18:52:13
Writing application                      : mkvmerge v4.0.0 ('The Stars were mine') gebaut am Jun  6 2010 16:18:42
Writing library                          : libebml v1.0.0 + libmatroska v1.0.0
Video
Format                                   : AVC
Format/Info                              : Advanced Video Codec
Format profile                           : High@L4.1
Format settings, CABAC                   : Yes
Format settings, ReFrames                : 4 frames
Codec ID                                 : V_MPEG4/ISO/AVC
Duration                                 : 1h 54mn
Bit rate                                 : 18.2 Mbps
Width                                    : 3 840 pixels
Height                                   : 816 pixels
Display aspect ratio                     : 4.706
Frame rate                               : 23.976 fps
Color space                              : YUV
Chroma subsampling                       : 4:2:0
Bit depth                                : 8 bits
Scan type                                : Progressive
Bits/(Pixel*Frame)                       : 0.242
Stream size                              : 14.2 GiB (87%)
Writing library                          : x264 core 116 r2074 2641b9e
Encoding settings                        : cabac=1 / ref=2 / deblock=1:-3:-3 / analyse=0x3:0x113 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.15 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-3 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=4 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=0 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=18200 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=40000 / vbv_bufsize=30000 / nal_hrd=none / ip_ratio=1.40 / aq=1:1.00
Language                                 : English
Default                                  : No
Forced                                   : No
Audio #1
Format                                   : AC-3
Format/Info                              : Audio Coding 3
Mode extension                           : CM (complete main)
Codec ID                                 : A_AC3
Duration                                 : 1h 54mn
Bit rate mode                            : Constant
Bit rate                                 : 640 Kbps
Channel(s)                               : 6 channels
Channel positions                        : Front: L C R, Side: L R, LFE
Sampling rate                            : 48.0 KHz
Bit depth                                : 16 bits
Compression mode                         : Lossy
Stream size                              : 526 MiB (3%)
Language                                 : German
Default                                  : Yes
Forced                                   : No
Audio #2
Format                                   : DTS
Format/Info                              : Digital Theater Systems
Format profile                           : ES
Codec ID                                 : A_DTS
Duration                                 : 1h 54mn
Bit rate                                 : 1 510 Kbps
Bit depth                                : 24 bits
Delay relative to video                  : 11ms
Stream size                              : 1.21 GiB (7%)
Language                                 : English
Default                                  : No
Forced                                   : No
Text #1
Format                                   : VobSub
Muxing mode                              : zlib
Codec ID                                 : S_VOBSUB
Codec ID/Info                            : The same subtitle format used on DVDs
Language                                 : English
Default                                  : No
Forced                                   : No
Text #2
Format                                   : VobSub
Muxing mode                              : zlib
Codec ID                                 : S_VOBSUB
Language                                 : Swedish
Default                                  : No
Forced                                   : No
Text #3
Format                                   : VobSub
Muxing mode                              : zlib
Codec ID                                 : S_VOBSUB
Language                                 : French
Default                                  : No
Forced                                   : No
Text #4
Format                                   : VobSub
Muxing mode                              : zlib
Codec ID                                 : S_VOBSUB
Language                                 : Finnish
Default                                  : No
Forced                                   : No
Audio: HDMI > LG 42LW4500
« Reply #1 on: May 12, 2012, 09:59:26 am »
I think it is because it is a full size SBS and not half size:
Height                                   : 816 pixels
With HDMI 1.3 not enough bandwith to play.
Skylinc
« Reply #2 on: May 15, 2012, 04:08:56 am »
Thanks, Maasbommel!
