Author Topic: Can you add custom cover from own jpg file?  (Read 592 times)
Webface
« on: April 28, 2012, 04:53:46 pm »
Hello, Is it possible to add own covers to a movie? I use YAMJ 1.0.6.
I know how to use .nfo but the movie is not in the database (IMDB or others).
I also tested thumgen but I want to use one program, that is YAMJ.
webface.
« Reply #1 on: April 28, 2012, 05:15:15 pm »
Just search for a cover and drop it with the name folder.jpg in the movie folder.
Unreal
B8a Tester - X2
« Reply #2 on: April 28, 2012, 08:58:51 pm »
You can also get custom covers with YAMJ without downloading anything...
01.  In the moviejukebox.properties (or moviejukebox-Mede8er.properties) file in the root directory where YAMJ is located be sure you have this entry...
filename.nfo.skipUrl=false
02.  In the movie.nfo file, include an entry similar to this...
<movie>
   <thumb>http://server.domain/pictures/movieposter.jpg</thumb>
</movie>
If you would like to have the poster on your local computer, but want it in a central directory (not in the movie folder), then...
<movie>
   <thumb>file:///C:\directory\path\images\movieposter.jpg</thumb>
</movie>
Make sure the poster is in portrait mode, not landscape, or it will not work.  I find the best size to be approximately 1000x1500, but I use a skin with large posters.  You may be able to use smaller, but the proportions should be the same (like 500x750 or 300x450).
MED450X2 with PCIe Wireless                                 Firmware 2.0.7, NAS on, 1080P 24Hz option on
Samsung USB Drives [2x2TB] (HX-DT020EB/B62)      D-Link N Gigabit Router (DIR-655)
Unreal
B8a Tester - X2
« Reply #3 on: April 28, 2012, 09:07:02 pm »
I missed it the first time, but you stated you are using YAMJ 1.0.6.  That version is so old I seriously doubt you can get it to work.  The latest dev snapshot is 2.7 r3065, and the current stable build is 2.6.1 r3000.
Webface
« Reply #4 on: April 28, 2012, 11:57:37 pm »
Thanks for the answers !
I downloaded the 2.0.0 to mede8er (feb 12 2012) and it works faster than 1.0  Smiley
1 Does the nfo trick not working anymore? I put the file (movie.nfo) in the moviefolder but nothing happens with it.
2 Also where can I change the database (imdb -> moviemeter)? maybee this is why nfo don't work.
3 I put also the file folder.jpg (the cover) in the moviefolder, but I can not see it in Y2M or does it only appear on the jukebox?
I use the jukebox.
Please some advice !
thanks in advance!
webface
Unreal
B8a Tester - X2
« Reply #5 on: April 29, 2012, 03:43:49 am »
YAMJ will not use the <thumb> entry in the NFO file unless you have filename.nfo.skipUrl=false in the moviejukebox.properties that I mentioned earlier.
