Author Topic: No USB3 cable provided.  (Read 258 times)
ggbarnum
« on: April 27, 2012, 04:52:12 pm »
This is not the perfect place for this question but it was the closest I could find Smiley
I have just bought a MED450X2 and want to transfer my library accross to the internal HDD, the manual says:
"Important, use the supplied blue USB3 cable for USB connection to your PC"
However, there is no such cable provided in the box !!
Is this a mistake in the manual or should I have actually received a USB3 cable ?
Many thanks,
GG.
« Reply #1 on: April 27, 2012, 05:18:23 pm »
It should come with a blue usb 3.0 cable - as also stated on the box as far as I am aware.
ggbarnum
« Reply #2 on: April 27, 2012, 05:32:06 pm »
Ok thanks, I thought as much.
I will make sure that nobody here "moved" it and then follow up with the shop I bought it from.
Cheers,
GG.
« Reply #3 on: April 27, 2012, 05:51:08 pm »
Was it a bundle, inclduing drive or pci-e wi-fi?  Then the box has to be opended by the distributer so that those can be installed. They might have left the cable out when they repacked.
ggbarnum
« Reply #4 on: April 28, 2012, 12:28:11 am »
Yep, it came with a drive fitted. So you could be right.
