Author Topic: Update 2.0.7 Open Beta problems  (Read 1337 times)
Beamcon
« on: April 24, 2012, 10:58:38 am »
Updated 500x2 unit to new update. I did not have issues with previous firmware but new should be better (usually).
Problems since update:
Unit reboots randomly.
Can't select more than one items to copy from ie: USB flash drive to Mede8Ter - it reboots itself
Sometimes randomly returns one step back
Hardware: 500x2 + Seagate SATA 1TB HDD (formatted in Mede8ter)
 Huh
Anny ideas or is there a update to the Open Beta
Beam
« Reply #1 on: April 24, 2012, 11:15:50 am »
Did you run 2.0.6 or 2.0.5 on the unit before the upgrade to 2.0.7?
Did you try a chkds on your internal drive to verify if your filesystem is ok?
Beamcon
« Reply #2 on: April 24, 2012, 11:34:51 am »
Not sure of update but downloaded in January 2012 (think it was 2.0.6)
Did not do a chkds on HDD. Would I need to connect to PC or does it have its own chkds on Mede8ter?
Did work fine on previous firmware though...
« Reply #3 on: April 24, 2012, 11:54:30 am »
You need to connect to a PC by usb cable to do this.
Read the 2.0.7 beta post release notes - you might be in the category that has issues with files to folders.
Beamcon
« Reply #4 on: April 24, 2012, 12:07:02 pm »
Will do check and reply when done. Tomorrow or day after
Beamcon
« Reply #5 on: April 26, 2012, 12:55:37 pm »
Hi
Did the chkdsk /f (through Windows and command-line - No change
Formatted USB flash drive and attempted again - No change
Tried to copy files from portable HDD - No Change
Still does the same - When copying a file from external devise, the unit re-boots itself just before file is finished.
                                       When copying multiple files from external devise, the unit reboots itself midway in the second file.
Is there something else to try ?
Beam
« Reply #6 on: April 26, 2012, 12:59:48 pm »
Try copying folders..not files..one folder at a time.
Beamcon
« Reply #7 on: April 26, 2012, 01:07:32 pm »
Some of the files are in folders.
This happened straight after 2.0.7 update
« Reply #8 on: April 26, 2012, 01:44:35 pm »
Did you run ntfsfix using bootmed?
Beamcon
« Reply #9 on: April 26, 2012, 01:45:44 pm »
No - should I try?
« Reply #10 on: April 26, 2012, 01:55:00 pm »
Read this:-
http://www.mede8erforum.com/index.php/topic,8327.msg52853.html#msg52853
If anything..we are finding 2.0.7 more active at "correcting" isues in the corrupt journal than 2.0.6 was, which created them.
You should also do the same to the USB drive whilst attached to the PC.
« Last Edit: April 26, 2012, 03:51:20 pm by jer1956 » Logged
