eentje, thanks so much for all your trouble!!! I'm a bit confused by the part below
"A good thing is I found a script that does it for u. Al you have to do for it is open notepad copy the text below. And save the files as (folder.bat) and copy that file to the directory you want and run it in."
Do I rename the text file copy.bat and place it in a movie folder i.e. hdd/blurays/action ?
I know...I'm absolutley brutal at this kind of thing!!!!!!
u save the file in notepad and then rename it to a .bat extension.
the script makes a folder with the samen name as the movie file and puts the movie file in it.
it other words if u got a dir structure like this:
hdd/bluerays/action/die hard 1.mkv
hdd/bluerays/action/die hard2.mkv
hdd/bluerays/action/the matrix.mkv
if u put that .bat file in that folder it will create a structure like this
hdd/bluerays/action/die hard 1/ die hard 1.mkv
hdd/bluerays/action/die hard 2/ die hard 2 .mkv
hdd/bluerays/action/ the matrix / the matrix.mkv
i hope this is understandable enough for u
