Author Topic: NAS on = Wifi off ?  (Read 1704 times)
Offline AEE
NAS on = Wifi off ?
« on: April 09, 2012, 06:53:29 pm »
With the new purchased 500X2 and antenna screwed in the back, I managed Wifi connection to network. After turning on NAS, no Wifi connection anymore. Restarting results in "No AP found" at Wifi setup. Any ideas ?
Re: NAS on = Wifi off ?
« Reply #1 on: April 09, 2012, 07:02:02 pm »
Did you turn on the NAS the first time you set up?  It could be a coincedence, that after the first reboot you lost pci-e, which is not unknown.
Offline AEE
« Reply #2 on: April 09, 2012, 07:15:34 pm »
Thanks for reply, however, tried several times, all without succes. Attached dongel from 'old' 400x and found network immediately. Two questions: Is antenna not compatible with 2.4 Db ? Why is Wifi not on after restart ?
« Reply #3 on: April 09, 2012, 07:29:47 pm »
Please check Setup, Network Info and see if there is a MAC number for wi-fi. Do this without the USB wi-fi attached.
Offline AEE
« Reply #4 on: April 11, 2012, 08:22:22 pm »
No MAC address was available, however, problem is solved. Apparently Firmware was ancient...
Newby error.
