Hi all
Recently got the 500xt - great product! Whips the limited playback I had on the PS3 and the MViX by a long shot! I can now watch MKV woohoo!
Couple of things:
I bought the device from Cats Digital in Greenstone - the package was already open, all the components (device, keyboard, cables etc) were open.. when I asked about this, they said they test each unit before selling incase it doesnt work - which I thought was a load of crap, but anyways.. I bought the "special", the device with the keyboard and wireless ability.. what exactly was supposed to come with the wireless ability? All I got was a small antena..??
I can't get my bluetooth wireless keyboard to work and I can't find instructions on how to pair the device with the 500x2. The one set of instructions I found says to plug in the keyboard to the device using the cable.. which I did, all it does is show the charging light.. when I switch on the keyboard, it shows the bluetooth light, but I cannot navigate the device. Please assist
Then some feature stuff:
It says in a review that it tracks what I've watched and shows me if I've watched a certain movie already - how do I see this? All the files/folders look exactly the same in both watched and unwatched items. Is this feature only available in a certain view mode?
Is it possible to set a max volume? Ie: some movies, if poorly recorded will have foreground sounds much softer than background music.. so its quite annoying when the movie cuts to say an action scene only to have the music blarring at a much louder volume than when people are speaking.. so is it possible to auto adjust this?
Some movies have out of sync lip-audio.. is it possible to re-sync? Like manually delaying the audio until its correct with the lip movement?
Thanks!
